Carbureted LS1 ?
Old Oct 12, 2008 | 07:32 PM
Exotix's Avatar
Exotix
From: Pyle Driver Sound ... when screaming naked ears demand sustained excruciating painful thresholds ! Starz Fall on Alabama
Default Carbureted LS1 ?
I didn't know you could ... anybody know what kind of intake manifold this is ?
This is an Iron LME 408ci in an '02 SS Camaro Pro Street
Old Oct 17, 2008 | 09:00 PM
Richard454's Avatar
Richard454
Yes you can carb a LS motor!!!
Edelbrock offers two manifold designs for the LS1--a Victor Jr. single plane and a Performer RPM dual plane.
GMPP also has a LS 3 w/ carb intake w/440HP crate motor for around $5k. W/ alum block & heads, it weighs in at 414 lbs!!!
For ignition- MSD sell a box that plugs right in and it has several preset timing curves you can chose from.
GMPP just let this one out- LSX 454- 620HP
Old Oct 18, 2008 | 01:09 AM
scottyp99's Avatar
scottyp99
And, apparently, you can get it to fit by hacking away at the cowl with a machette!!!
Scott
Old Oct 24, 2008 | 12:40 PM
Exotix's Avatar
Exotix
Outstanding !
Old Nov 16, 2008 | 12:05 AM
10gears's Avatar
10gears
Originally Posted by Exotix
Outstanding !
hay it works ???
Old Nov 16, 2008 | 02:41 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
They make a distributor drive for it too.
http://paceperformance.com/index.asp...&ProdID=180629
The GM front cover assembly is manufactured for application where a 4-bbl carburetor and distributor are required. It can be combined with GM's new Bowtie valve covers p/n 25534398 & 25534399 for a complete traditional looking engine package.
Old Nov 16, 2008 | 06:30 PM
grn envy's Avatar
grn envy
Cruise-In X Veteran
Find holley505 he has a carb setup on his ls1.
To Carbureted LS1 ?
