Question About Compression and Head Gasket !
Old Oct 27, 2008 | 07:41 PM
larry00's Avatar
larry00
Default Question About Compression and Head Gasket !
I have a 383 LT 4 with ported Stock Heads and JE dished Blower pistons.
No boost now but It will get 8 lb's from D 1 later.
It has 9.8.1 compression with .29 head gaskets .
What compression loss could I expect with .40 gaskets.
I either need to boost [ don't want to blow gaskets either ] or do a piston change and get compression up to 11.1.
Rather boost but worried about too much compression.
What should be the max compression you would want on a street/strip aluminum headed engine on 8 lb's boost.
Old Oct 28, 2008 | 05:49 AM
gkull's Avatar
gkull
Just find an online compression calc program and plug in the piston to deck, negative piston cc, chamber cc, head gasket size.
Since 95% of the time blower motors are not running on boost you need some compression. Again you need supercharger boost vs static compression ratio calcs.
Old Oct 29, 2008 | 10:55 AM
larry00's Avatar
larry00
Found an article in CHP and if I go with .51 thickness over the .29 I will loose 4 tenths down to 9.4.1 which is not that much.
With the MSD rev limiter I can get by with the 9.8.1 w/8 lb's boost at 6200 so I guess changing thickness not the easy fix.
Would like to drop to at least 8.8.1 with 8.5.1 better.
Heads just too dang small .
I feel a new set of heads in the offing w/76 cc chambers.
More research needed.
To Question About Compression and Head Gasket !
