supercharger installion complete now ?
Old Jan 20, 2002 | 06:00 PM
Dennis McDougle's Avatar
Dennis McDougle
Default supercharger installion complete now ?
I fired her just to make sure all was working now a question for those in the know. I have read all of the vortech instruction and understand there way of driving and setting just after detonation, I would like to know from those in the know if ther are any precaustion or anything you might suggest above and beyond what is in the book. THANKS to all that suggest.
Old Jan 21, 2002 | 01:36 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: supercharger installion complete now ? (Dennis McDougle)
I don't have a supercharger, I have a blower so they act a little differently. Take it for a drive, you will not really get any boost at normal driving speeds. Yours is rpm dependent so boost will rise with rpm. You won't hurt anything in normal driving. Let us know how it goes.
Good luck
Old Jan 21, 2002 | 07:47 PM
GlockLT4's Avatar
GlockLT4
Default Re: supercharger installion complete now ? (norvalwilhelm)
I thought a blower and SC were the same thing :confused: :confused: Sorry, I'm not much into forced induction really.. i'm all N/A What's the difference?
Old Jan 21, 2002 | 08:58 PM
art91's Avatar
art91
Default Re: supercharger installion complete now ? (Glock'94)
Norval has an 8-71 roots type blower (supercharger) on his Vette. Just picture a top fuel dragster motor. :D
C4, and C5 superchargers are centrifical, like a turbocharger. They are pulley driven, and force air into the intake, where it is then mixed with the fuel. With a roots type supercharger, the carbs/injectors are on top of it. This requires cutting a hole in the hood for clearance.
Old Jan 21, 2002 | 09:25 PM
GlockLT4's Avatar
GlockLT4
Default Re: supercharger installion complete now ? (art91)
Oh, never mind.. i knew that ;) ... blowers sit on the intake, SC's are an "accessory" :D
Old Jan 21, 2002 | 10:09 PM
korvetkeith's Avatar
korvetkeith
The terms are usually interchangeable.
Old Jan 22, 2002 | 11:13 AM
norvalwilhelm
To me a supercharger is like a large fan that makes boost with rpm. There maximum boost comes in at maximum rpm. At 3000 they make little or no boost. A blower sits on top of the intake and make boost at any rpm so long as the throttles are open. The blower is larger then the engine it is feeding , but the carbs restrict it's ability to breath. Open the carbs and the blower suddenly gets all the air it wants and it instantly probuces boost. I can get 10 psi by 1500rpm. My wife has a SSEI supercharged bonneville and it has a blower on top of the motor. It gives 8psi boost anytime you ask for it . Smooth flow of power at any rpm
This is my 8-71 blower on a 460.
Old Jan 22, 2002 | 12:57 PM
GlockLT4's Avatar
GlockLT4
:cool: :cool: :cool:
Old Jan 22, 2002 | 05:55 PM
RVY's Avatar
RVY
Dennis, without hesitation buy a large Bosch intank fuel pump (drop in installation). Without it your probably running a 13.8 to1 air fuel ratio which is way to lean. When the snow starts to melt get a dyno tune to adjust the computor. If your running sunoco 94 you may not have any problem. If so, a1/4 point adjustment on the retard may be all that is necessary. If the wallet permits discard the Vortech supplied air intake to the supercharger. Have a custom made 4" intake installed. Have fun.
To supercharger installion complete now ?
