What size rocker studs?
Old Jan 26, 2002 | 11:03 PM
88-406's Avatar
88-406
St. Jude Donor '05
Default What size rocker studs?
What size are you guys running? 3/8 or 7/16? What factors determine this anyhow?
KM
Old Jan 27, 2002 | 12:55 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Default Re: What size rocker studs? (88-406)
Bigger is better!! Especially if you are running big cam or lots of spring pressure and rpm.
Can't think of any downsides. Parts really don't cost anymore if you're starting from scratch.
Jim
Old Jan 27, 2002 | 02:52 AM
ChrisB's Avatar
ChrisB
Default Re: What size rocker studs? (427Hotrod)
7/16th's - don't bother with anything else!
Old Jan 27, 2002 | 04:29 AM
ol,RJ's Avatar
ol,RJ
go with the 7/16"
I think ARP is making some that are aligned better than most other aftermarket ones. (you would be suprised to see how far off center they can be :eek: ).
this will help when it comes time to line up the rockers with the valves.
RJ
Old Jan 27, 2002 | 07:22 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: What size rocker studs? (ChrisB)
Sounds like I need to sell my 3/8 1.6RR valve train parts and go with 7/16 stuff.
KM
Old Jan 28, 2002 | 08:49 AM
ram82fire's Avatar
ram82fire
I have a set for sale never used 7/16 arp
Old Feb 1, 2002 | 06:11 PM
GlockLT4's Avatar
GlockLT4
Default Re: What size rocker studs? (ram82fire)
Over summer I need to upgrade to some Magnum rockers with 7/16ths studs :yesnod: :yesnod:
Old Feb 1, 2002 | 08:52 PM
CFI-EFI's Avatar
CFI-EFI
The stock studs are 3/8ths. If you have the press in studs and have bought roller rockers for them, then it'll cost you to convert. If you're starting with new heads it's cheap to go to the 7/16ths studs. The rockers cost the same either way. Particularly if you don't have to replace GOOD 3/8ths rockers. What nobody has mentioned, is that the heads for screw in studs are tapped for 7/16ths threads. The stock screw in stud is 7/16ths couse, in to the head and 3/8ths fine, for the rocker. The good studs are 7/16ths-7/16ths. With a fresh set up, with screw in heads, the worse it could cost you is a wasted set of unused 3/8ths studs.
[Modified by CFI-EFI, 6:55 PM 2/1/2002]
To What size rocker studs?
