piston bore rod / clearance
Old Mar 27, 2009 | 08:30 PM
LD85's Avatar
LD85
Default piston bore rod / clearance
My new H-beam rods hit the lower corner of the #1 & #2 (so far) piston bore, where there seems to be ragged casting material on the block.
I assume that this can be relieved enough for the H-beam to clear.
Am I correct in this assumption ?
Components are, 1978 stock 400 block, 4340/3.75 eagle crank and eagle h-beam rods
Thanks in advance
Old Mar 27, 2009 | 11:34 PM
BLOCKMAN's Avatar
BLOCKMAN
Should not be a problem
Old Apr 3, 2009 | 04:59 PM
vettef6's Avatar
vettef6
Just sent you a few pictures.
Arnold
To piston bore rod / clearance
