distributorless ignition system
Old Feb 2, 2002 | 10:03 AM
Monty's Avatar
Monty
Default Re: distributorless ignition system (tntcorvette)
I recently bought the FAST/SpeedPro eDist distributorless ignition to go along with the FAST/SpeedPro SEFI, but I haven't installed it yet. I still need to buy the coils and a DIS MSD ignition box. If no one else responds, Ill let you know in a month or so, if you're still interested.
Old Feb 2, 2002 | 11:03 AM
gkull's Avatar
gkull
Default Re: distributorless ignition system (Monty)
Monty - do you have a site add? I would like to look up some info. I just took my Mallory Unilite down for a recurving ............. While I was there I got to talking to Earson Cam supervisor. They use Crane Cam blanks and he would make custom cams how ever I want for $225 out the door if I would run their stickers. That was for the small base circle sleeved gear. When I told him about my cam he suggested more than the 8 degrees split that I have on all solid rollers. Really nice guy.
The other good news that I never even knew about is they have all new motor and chassis dyno facility.
Is this the site?
http://www.fuelairspark.com
[Modified by gkull, 9:05 AM 2/2/2002]
[Modified by gkull, 9:45 AM 2/2/2002]
Old Feb 2, 2002 | 06:03 PM
Monty's Avatar
Monty
Default Re: distributorless ignition system (gkull)
Yep, that's it. Also, MSD just released a DIS dox as well that is pretty equilvalent.
Old Feb 2, 2002 | 07:21 PM
DOCTOR J's Avatar
DOCTOR J
I'm curious too. Where does the DIS get crank and cam angle readings on this system?
drj
Old Feb 9, 2002 | 05:49 AM
GlockLT4's Avatar
GlockLT4
Default Re: distributorless ignition system (DOCTOR J)
Talk to someone with an LS1 :p: :p: :jester
Old Feb 9, 2002 | 10:29 AM
Monty's Avatar
Monty
You will need a crank trigger and a cam plug with sensor - both available from MSD.
Old Feb 9, 2002 | 01:21 PM
DOCTOR J's Avatar
DOCTOR J
Thanks, Monty.
I always wondered where they inserted the cam angle sensor for a SBC - I see now it's on the oil pump shaft. One of the people on DIY-EFI had hooked up a DIS using the GM computer & spark module (no MSD box). Now I think I know how he did it. Very interesting.
[Modified by DOCTOR J, 12:21 PM 2/9/2002]
To distributorless ignition system
