Which flexplate to use?????
Old Feb 4, 2002 | 09:29 PM
dtorc4's Avatar
dtorc4
Default Which flexplate to use?????
I need to know whether to use a 153 or 168 tooth flexplate. The block casting # is 14093638 if that makes a difference. It has factory roller rockers, 2 bolt main, 1 pc. seal. I will be using the stock starter from my 85 on my stock 700r4 w/ a Yank stealth converter. Any other info you need, let me know. Thanks. :cheers:
Old Feb 5, 2002 | 11:45 AM
Lt1er's Avatar
Lt1er
Default Re: Which flexplate to use????? (dtorc4)
As far as I know all passenger cars with small blocks came with 153 tooth. If your starter doesn't have two sets of mounting holes it will only bolt to a 153.
