What would be the HP differance between these cams
Old Feb 8, 2002 | 08:34 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default What would be the HP differance between these cams
I have a buddy who likes the motor I have built in my 69. He is looking to do the same thing in a 68 vert, except he does not like the idea of a solid roler. He does not want any hassle of doing the valves. I even told him I would do the adjustments for him, he said he would not let me any where near his car with tools :chevy
My motor is a 454 +.030
Holley 850 flows 920
Edelbrock RPM Air gap
Edelbrock RPM heads
10.5 JE
L-88 rods
Hooker super comps 1 7/8
Roller rockers
MSD everything
My cam is a solid roller .646 .653 242 and 246 @ .050
I think my friend will lose a lot of HP going with the cam he wants to run it is
.552 .555 230 and 236 at .050
I am thinking somewhere in the neighborhood of 50-60 hp.
Any opinions :chevy
Old Feb 8, 2002 | 09:25 PM
bence13_33's Avatar
bence13_33
Default Re: What would be the HP differance between these cams (69 N.O.X. RATT)
I take it he wants to go with a hydraulic roller instead of a solid roller?
Old Feb 9, 2002 | 01:07 AM
69 N.O.X. RATT
Default Re: What would be the HP differance between these cams (bence13_33)
It is a flat tappet hydraulic :chevy
Old Feb 9, 2002 | 01:08 AM
bence13_33's Avatar
bence13_33
Ouch. Let me run it through the DD2000....
*EDIT*
Rectangle or Oval Port?
[Modified by bence13_33, 11:12 PM 2/8/2002]
Old Feb 9, 2002 | 01:27 AM
bence13_33's Avatar
bence13_33
DD2000 has your engine with the solid roller cam & R-Port heads putting out peak HP & TQ of:
547HP @ 5500RPMs
563TQ @ 4000RPMs
That's with small tube headers and mufflers.
DD2000 has your friend putting out about (w/ same setup except cam):
472HP @ 5500RPMs
518TQ @ 4000RPMs
That's with a hydraulic flat tappet cam similar to the Comp Cams XE274. He's leaving a good bit of power on the table with that cam choice. If money isn't an issue I would recommend that he go with a hydraulic roller cam.
[Modified by bence13_33, 11:27 PM 2/8/2002]
Old Feb 9, 2002 | 01:36 AM
69 N.O.X. RATT
Thanks bence :chevy
To What would be the HP differance between these cams
