Big Block rebuild....need some tips
Old Jul 27, 2009 | 08:49 PM
rahaul's Avatar
rahaul
Default Big Block rebuild....need some tips
Can anyone suggest a link for rebuild tips? It's a simple rering, rods, mains. Ate the cam/ lifters and trashed the engine. Last rebuild was me and Chiltons in 1996. Looking for latest/ greatest tips. I can dig the Chiltons back out if I have to.
Engine: '71 454 LS6 crate motor stock bore
balanced/ blueprinted
4 bolt / steel crank rods .20 mains .10
rectangle port heads
All GM except Bullet cam / Morel roller hydralic lifters
Street application
Also, in '96 I polished the alum intake and applied 2 coats of Eastwood Polished Alum clear coat. It looked great for 5 or 6 yr but slowly started looking tired. After stripping it I discovered the alum had actually begun to oxidize under the clear coat. Has anyone had better luck with anything else?
Thanks in advance
Old Jul 28, 2009 | 03:31 PM
Richard454's Avatar
Richard454
Here's a good book- at a Big Block price-$80+ but there are some used ones out there for $20+.
http://www.amazon.com/Modify-Chevrol.../dp/0760302030
It's next on my buy list.
Richard
