oil pump install
Old Feb 16, 2002 | 11:03 PM
BC66's Avatar
BC66
Default oil pump install
Hi , any of you guys know offhand if there is supposed to be a gasket between the oil pump and the main bearing cap that it mounts to? This is on my 66 327 I'm rebuilding. I have a new H.V.oil pump and a complete engine gasket kit ,neither of them contain one. I hope to finish assembling my engine tommorow.
Thanks Bruce :smash:
Old Feb 16, 2002 | 11:58 PM
Barry's70LT1's Avatar
Barry's70LT1
Default Re: oil pump install (BC66)
No gasket required. It's a metal to metal fit.
Old Feb 17, 2002 | 10:31 AM
BC66's Avatar
BC66
Default Re: oil pump install (Barry's70LT1)
Thanks Barry
I thought so , time to get to work.
Bruce
Old Feb 17, 2002 | 10:36 PM
Turbo-Jet's Avatar
Turbo-Jet
use some non-hardening sealant on the mount faces, just a bit. also, the machined finish on the pump cover is not very good. if you want, you can lap it smooth to improve the seal.
Old Feb 18, 2002 | 10:15 AM
BC66's Avatar
BC66
Default Re: oil pump install (Turbo-Jet)
Thanks Turbo the sealer sounds like a good idea.
Bruce
Old Feb 19, 2002 | 06:44 PM
The Dude's Avatar
The Dude
I think some guys would suggest not using sealant of any kind on the pump-to-cap mating surface. This would be to avoid having any of it breaking or sloughing off and getting into your oiling system. But, hey, do what ya gotta do.
Old Feb 19, 2002 | 10:38 PM
BC66's Avatar
BC66
Default Re: oil pump install (The Dude)
Thanks Dude I thought of that too , so I left it metal to metal like Barry had sugested. Plus I hate taking anything apart after its together and torqued.
Bruce
Old Feb 19, 2002 | 11:57 PM
Turbo-Jet's Avatar
Turbo-Jet
a little of a non-hardening sealant will cause no problems at all (permatex #2 ?). typically the machined faces of both the bearing cap and pump face are poopie, so a some sealant there will fill the gaps and ensure all the flow is going to the engine.
Old Feb 21, 2002 | 07:58 PM
BC66's Avatar
BC66
Thanks Turbo I ended up taking it back off for other reasons. So I think I will go with a little #2 . Better safe than sorry .
Thanks again ,Bruce
To oil pump install
