Can someone run these numbers
Old Feb 17, 2002 | 02:49 AM
Cory1970's Avatar
Cory1970
Default Can someone run these numbers
If someone could desk top dyno my new egine I would be very greatful. I am running 10.5 to 1 TRW pistons on a 355. I have the corvette/Z28 double hump heads with the 2.02 intake vavles and comp cam rocker arms with roler tips. I am running a 274H extreme energy comp cam. It has a .487/.490 lift. On top I am putting on a AIR GAP RPM intake with a holley 750 double pumper with mechanical secondaries. All of this is fired by a mallory unilight electronic distributor. Exhaust exits with hooker competition headers. I hope this thing makes good power.
:confused:
Old Feb 17, 2002 | 04:51 AM
1979toy's Avatar
1979toy
Default Re: Can someone run these numbers (Cory1970)
365 HP at 5000 RPM
410 TQ at 4000 RPM
Old Feb 18, 2002 | 10:52 PM
Cory1970's Avatar
Cory1970
Default Re: Can someone run these numbers (1979toy)
Anyone know what i can do to get this to 400 hp??????
Old Feb 18, 2002 | 10:56 PM
Cory1970's Avatar
Cory1970
what hp are you running
Old Feb 19, 2002 | 02:44 AM
1979toy's Avatar
1979toy
Cylinder heads. Iron will be fine, but you need flow. Dart, AFR or W/P Sportsman.
My engine has about 350 HP according to DD.
Old Feb 19, 2002 | 04:45 PM
compuvette's Avatar
compuvette
I get 422HP if you switch to a set of Sportsman II's with the same specs. You could also get your heads ported. What valves are in the heads you have? I ran the numbers based on 1.94/1.50. Also, I got the same base numbers as 1979toy. Is your car an auto or a stick? Gears? That is a big cam you have there.
Old Feb 19, 2002 | 04:57 PM
Cory1970's Avatar
Cory1970
Default Re: Can someone run these numbers (compuvette)
my valves are 2.02 and 1.60... can someone run thoses numbers with the my set up? :cheers:
Old Feb 19, 2002 | 05:17 PM
compuvette's Avatar
compuvette
O.K. This time I get:
381HP@5500
398LB@4500
If you switch to a single plane with that cam you get:
405HP@5500-6000
402LB@4000
You loose about 30LBs at 2000 tho. You never mentioned if you had a stick or an auto. With that cam and an auto you would definetly need a high stall converter.
Old Feb 19, 2002 | 11:37 PM
Cory1970's Avatar
Cory1970
I have a muncie M21 4 speed. What single plane will fit under my hood?
Old Feb 19, 2002 | 11:48 PM
Cory1970's Avatar
Cory1970
try running them with 10.3 to 1 compression .... i am havig a hard time finding 10.5 pistions
Old Feb 22, 2002 | 05:57 PM
compuvette's Avatar
compuvette
Sorry I haven't got back sooner. I will run them tonight. I was in Denver on Business.
To Can someone run these numbers
