Big problem, need help fast
Old Feb 17, 2002 | 08:57 PM
Classicvette63's Avatar
Classicvette63
Default Big problem, need help fast
My step-dad has a '66 w/427. The thing shut off on him tonite and had to be towed home. The unside of the air cleaner lid is covered with condensation. Inside the valve covers is a thick milky white fluid. The dipstick is covered with the same white fluid. The engine was just recently rebuilt so he is going to have that guy look at it. What could be wrong and more importantly, is there anything we should do tonight to prevent anymore damage? I am assuming there is water in the pistons. Should anything be done tonight about that? Any help is greatly appreciated. Not a happy camper, Classic
Old Feb 17, 2002 | 10:00 PM
jimduchek's Avatar
jimduchek
Default Re: Big problem, need help fast (Classicvette63)
Was the engine properly broken in?
Jim
Old Feb 17, 2002 | 10:11 PM
Classicvette63
Default Re: Big problem, need help fast (jimduchek)
Yes, he put 500 easy miles on it and then took it back for an oil changes and final adjustments. This was a couple of months ago. Classic
Old Feb 17, 2002 | 10:28 PM
jimduchek's Avatar
jimduchek
Does sound like water. Only ways water can get into an engine are A> driving through HUGE deep puddles and sucking it into the intake, and somehow I doubt he'd have done that ina ' big block!!!, B> head gasket blown and coolant goes into a cylinder or into the oil.. Shouldn't happen on a quality engine build.. C> you got crappy gas w/water in it. Or the gas cap lid didn't seal properly. Or something like that.
Not much you can do. Hopefully the engine builder will be able to help.
Jim
Old Feb 17, 2002 | 10:48 PM
Classicvette63
I just checked the radiator. Empty. It wasn't empty when he left earlier today. Sounds like a major rebuild. Classic
Old Feb 17, 2002 | 11:39 PM
hookedup's Avatar
hookedup
Sorry to hear about the problem, either a blown head gasket or even worse a cracked block or head. Hope its just a gasket, :nonod: :( :sad:
Old Feb 18, 2002 | 03:59 AM
Jvette73's Avatar
Jvette73
If the proper thread sealer is not used on the headbolt threads, engine coolant can leak up past the threads and out past the head of the bolt and into the crankcase. This could have made the coolant run low over time. Running with low coolant will eventually cause big problems like overheating and cracked heads or block.
Old Feb 18, 2002 | 02:09 PM
jimduchek's Avatar
jimduchek
Default Re: Big problem, need help fast (Jvette73)
If the engine had been checked for coolant before the drive, and was empty afterwards (unless it was a very long drive) -- I doubt it was headbolt threads -- that's a fairly low-flow coolant leak. Sounds like a cracked block (hope not, if it's the original engine!!!) or a severely blown out head gasket. Hoping for the best for you and your pops.
Jim
Old Feb 18, 2002 | 04:42 PM
88-406's Avatar
88-406
St. Jude Donor '05
One other thing to check for is a loose Intake Manifold! water can leak down into the lifter valley if it's not sealed up properly.
Good Luck
KM
Old Feb 18, 2002 | 05:07 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
DEFINETLY SOUNDS LIKE A BAD HEAD GASKET! SORRY TO HEAR IT. GOOD LUCK FIXING HER. :sad:
Old Feb 19, 2002 | 01:22 PM
GregP's Avatar
GregP
If it got enough water in the cylinders to quite running the rods/crank are likely bent (water doesn't compress). Only way to get that much water in would be from a cracked block, as head gaskets usually just allow enough in to get a good cloud of steam.
Old Feb 21, 2002 | 10:38 PM
Classicvette63
Default Re: Big problem, need help fast (GregP)
Thanks guys. The guy said he can't look at it until early March :mad . I 'll keep ya' posted how he makes out. Classic
To Big problem, need help fast
