Need Help!!!!!
Old Feb 17, 2002 | 10:26 PM
snaketr's Avatar
snaketr
Default Need Help!!!!!
I also posted this in the C4 section, but I know there are some that hang out here have done this. I am working on converting two C4's into 6 speeds that were auto's. The one I was working on tonight is an 85 with a 406 and now ZF 6speed. However I went to bolt the pedals in and they will not work. It looks as if the aluminum support running across the dash is different. Has anyone replaced this or did you just make the pedal work. I am using the factory pedals from a 4+3 85.
