engine/motor, motor/engine?
Old Feb 26, 2002 | 01:53 PM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
Default engine/motor, motor/engine?
Yes, I'm bored at work. But the question which remains is this:
True or False. All motors are engines, but not all engines are motors.
:cheers:
Old Feb 26, 2002 | 02:07 PM
dtorc4's Avatar
dtorc4
Default Re: engine/motor, motor/engine? (TrueBlue ChevyDude)
Technically, no engines are motors. A motor is an electric device, an engine uses some form of combustion. Have fun at work!! :cheers:
Old Feb 27, 2002 | 08:32 AM
mountainmotor's Avatar
mountainmotor
Default Re: engine/motor, motor/engine? (dtorc4)
I always wondered why Japanese Kamakazi Pilots wore helmets?
Yep! Reciprocating Engines
Old Feb 27, 2002 | 09:11 AM
TrueBlue ChevyDude
I was thinking, like, all motors are engines, but not all engines are motors.
A motor is something which brings about movement.
An engine is something which, for lack of a better phrase, takes in "X" at one end and puts out "Y" at the other. An IC engine takes in fuel/air and puts out rotational force. A math engine takes in numbers/variables and puts out solutions.
So you could call what's under your hood either, but you can't call a calculator a motor.
Yes, I'm bored, but it's not my fault. I mean, why else would they install a fast Internet connection? So I can troll the boards, right?
Old Mar 7, 2002 | 04:22 PM
JAKE's Avatar
JAKE
dtorc4 nailed it.
Using precise language, engines and motors are completely different animals, but we often use the terms interchangeably. A rose by any other name . . .
Jake
To engine/motor, motor/engine?
