1 bar, 2 bar & 3 bar map sensor ?
Old Mar 3, 2002 | 11:07 PM
h rocks's Avatar
h rocks
Default Re: 1 bar, 2 bar & 3 bar map sensor ? (tntcorvette)
That would make sense, although 30 to 45 Lbs of boost would along the line of Big Daddy's TF dragster! Seriously, I don't know if it's a one# for one# direct comparison, I would doubt it. Anyway, Porsche's boost gauge is in "bar". (15 lbs = 1 bar) Hope this helps.
Old Mar 4, 2002 | 07:46 AM
mrvette's Avatar
mrvette
Seal level pressure is about 15 lbs...considered one bar....
so 2 bar would be 30 lbs....3 bar 45 lbs..etc....
Old Mar 4, 2002 | 08:06 PM
gcrouse's Avatar
gcrouse
Default Re: 1 bar, 2 bar & 3 bar map sensor ? (mrvette)
In other words:
1 bar MAP for NA
2 bar MAP up to 15psi boost
3 bar MAP over 15psi boost
To 1 bar, 2 bar & 3 bar map sensor ?
