I got my car started today and ran it for a while. I noticed coolant coming out of a few of my lower head bolts. I put some block sealer in hoping it would help but it didn't. Do I need to retork and will that fix the problem or should I just take off and put a good set of Felpro. I plan for it to be a daily driver, but still want to take to track and possibly run up the boost higher. I did tork to spec and sequence. I also O-ringed the block. Any input would be help. Thanks :seeya
Did you forget to put thread sealer on all the head bolts?
I've heard Copper head gaskets need sealer around the water passages, and are best for racing. :chevy
yeas ago that was all we used....we ALWAYS re-torqued.....
that might be all you need to do, get the motor hot and re-torque.
it's always a pain to take every thing off to do it....but it's the way to go.
I've just come across a problem with my copper gaskets. I have been trying to find out as to why my car will not stay running, "first time starting it since twin turbo build." Anyways, I checked the compression, and it was saying around 60 psi. I am kinda worried about this, seeing that I sealed all the bolts and torqued them down to 70 pounds in the correct sequence. I used Copper sealer on both sides. and have the heads O-ringed. I don't see how they could be leaking. I started to wonder about the compression tester, thinking it could be faulty or no threaded in tight enough, but ended up breaking it as I was trying to Tighten it more. "update, I got a new tester, but left ignition on and batterys dead now. Waiting for a charge.
Is 60 pounds infact too light of pressure?? 8:1 compression ratio. or at least thats what I have been told that my setup would create.
Your cranking compression should be alot higher. At least 150 and up. Copper head gaskets are more prone to seeping fluids not leaking. Even if you had a leaking gasket not all cylinders would leak. Try a leak down test or at least apply if you have a compressor high pressure air to the cylinder. A good cylinder will turn the motor over and very leakage can be heard. A poor cylinder will not turn over and it sounds like alot of leak. I prefer leak down tests to compression tests.
Either way 60 psi is too low. Even wild cams have more cranking pressure then this.
How high are your o-rings sticking up out of the block? When o-ringed, you need a pretty thick gasket for it to seal right. For example, my o-rings are .010 up and the gasket folks told me I needed to use a .062 gasket minimum for it to seal right. (referring to my drag race car engine, not my Vette...)
