Electric water pumps
Old Mar 20, 2002 | 02:25 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Electric water pumps
Who makes the best one for street use? If I want to get one to work on a L98 type setup, what do I do with the Serp? any pictures?
KM
Old Mar 21, 2002 | 02:06 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: Electric water pumps (88-406)
ttt
Old Mar 21, 2002 | 07:18 AM
V-Twin's Avatar
V-Twin
Check out http://www.csiperformance.com and http://www.meziere.com
As for the serpentine? Maybe a shorter belt?
Xander
Old Mar 21, 2002 | 12:36 PM
aobrien's Avatar
aobrien
How reliable are the electric water pumps? Would you put one on your daily driver?
Old Mar 21, 2002 | 03:52 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Electric water pumps (aobrien)
I would run the CSI or the Meziere one without a doubt. Then again, I don't drive my 82 that much (now it's not driveable at all!)
The meziere one has a seal life expectancey of 2000 hours. Both units are rebuildable and the csi one comes standard on the corvette boat
Marck
[Modified by Twinnie, 1:53 PM 3/21/2002]
Old Mar 24, 2002 | 03:46 PM
gcrouse's Avatar
gcrouse
No way, no how! Unless I lived in Alaska....
Old Mar 24, 2002 | 08:27 PM
vader86's Avatar
vader86
Default Re: Electric water pumps (gcrouse)
Meziere
Old Mar 25, 2002 | 11:20 AM
L79vette's Avatar
L79vette
Go to http://www.stewartcomponents.com/chevyS1.htm
There is a Q&A forum. According to Stewart, you are looking at about 2HP at 6000RPM to drive a good mechanical pump. Definitely makes it not worth the electrical hassle and short life, in my opinion.
Old Apr 1, 2002 | 12:39 AM
Nathan Plemons's Avatar
Nathan Plemons
I have a meziere and have personally put over 13k miles on it in less than a year without any issues whatsoever. I also know about 3 other people locally who have never had a problem with one. They don't cost that much more than a stock replacement and have just as good a life expectancy while putting about 7 hp to the ground.
All the people I know are running them on LT1 cars though, so I don't know what you would do about your belt.
Old Apr 1, 2002 | 05:42 PM
John Row's Avatar
John Row
I put the Mez on my LT1, it's not quite a daily driver, but we do put a lot of miles on it. No hesitation on taking a 1000 mile trip 2 weeks ago.
Plus it dropped my temps about 10 degrees.
The only problems I've heard where either relay or fuse related.
Old Apr 1, 2002 | 09:10 PM
turbocat's Avatar
turbocat
Im doing one right now on a l98 -though it is a twin turbo its still the same belt routing. Removed the air pump next to the alternator and the diverter valve next to the air conditioning pump. belt goes across the top of the alternator straight over to the air conditioner below the throttle body. You can get any length of belt you need at a auto parts store-its just a trial and error thing to find the right length.
To Electric water pumps
