Nitro and Compression
Old Mar 23, 2002 | 11:53 PM
bulldogg's Avatar
bulldogg
Default Nitro and Compression
In the process of building a 400-427sbc for my 88.
My plan is to have my compression around 11.5 to 12 to 1 non aspirated. I plan to run pump gas 93 with a mix of turbo blue, probably to get my octane level to 97-99. Was needing to know if thats enough octane with the nitro shot as well. Nitro package comes with 75-100-150-200 jets.
I've heard that the nitro isn't as octane sensitive as a blower or turbo is. But still I am forcing air in. Would like to hear some of your input, experiences. Thanks
Old Mar 24, 2002 | 01:46 PM
Bruce's Avatar
Bruce
Default Re: Nitro and Compression (bulldogg)
You have nothing to worry about. You can run N2O with with high compression. Actually N2O like high compression any way. Unlike forced induction applications is the opposite. You look at those drag racer running 13:1 + compression and dumping 300-500hp shot of N2O.
Bruce
93LT1 Conv w/ZF6
top end mods
jetted 150hp NX
Blown 383ci is in the works
Old Mar 24, 2002 | 03:41 PM
gcrouse's Avatar
gcrouse
Nitromethane is a bit much for a street car don't you think???
Old Mar 24, 2002 | 06:53 PM
Jenny's Avatar
Jenny
Default Re: Nitro and Compression (gcrouse)
Nah :D
btw- which mix are you using? 10%?
Old Mar 25, 2002 | 02:56 PM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
Default Re: Nitro and Compression (Jenny)
Nitro is a fuel, nitrous is a power adder, and too much nitrous+high compression equals BOOM!
Old Mar 25, 2002 | 04:18 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Nitro and Compression (TrueBlue ChevyDude)
I thought he was talking about Nitrous and it is not bothered by high compression. They run 15 or more compressions and still run large doses of nitrous. Nitro methane itself is a poor fuel and pound for pound gas far outdoes it.
Old Mar 25, 2002 | 08:43 PM
bulldogg's Avatar
bulldogg
Default Re: Nitro and Compression (norvalwilhelm)
I was talking about Nitrous. Was using slang, sorry for the misunderstanding.
Haven't heard of Nitro Methane.
Old Mar 25, 2002 | 08:54 PM
bulldogg's Avatar
bulldogg
But why? Is it because not enough octane was run?
Some motors can run on pump gas with 11 to 1 compression. So if it is bumped up 5 points with either a mix of Turbo Blue or C16, is that enough octane to elimate spark knock, which can kill a motor?
To Nitro and Compression
