all aluminum smallblock?
Old Mar 29, 2002 | 02:51 PM
Z062's Avatar
Z062
Default all aluminum smallblock?
can anyone tell me if there is an all aluminum crate motor out there? it needs to be gen one. something similar to the zz4 shortblock? if not, who sells a good aluminum block for non race applications. im planning to build an ultralight motor for a boss hoss.
thanx :cheers:
Old Mar 29, 2002 | 03:43 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: all aluminum smallblock? (half-a-62)
The Z06 is all aluminum. GM never used an aluminum Gen I SBC in production. They did (do?) sell a bare block, part number 366300, with a 4" bore, and 4 bolt splayed outer bolt mains. Also, there are aftermarket blocks available. I have never seen a "crate" sbc cataloged with an aluminum block, probably due to cost. I'm sure one of the builders would be happy to put one together, though. You may need to put up your key to Fort Knox, as collateral. Good luck.
Old Mar 30, 2002 | 01:04 AM
Bill Reid's Avatar
Bill Reid
Default Re: all aluminum smallblock? (CFI-EFI)
PAW sells an Aluminum small block kit... assembly required. Year 2000 prices (Y2K catalog page 61) were $7099 for the short block, $8595 for the long block.So, no its not a crate motor. They are QUITE expensive. Just like CFI-EFI said aftermarket blocks are available... personally I don't see any advanatge unless weight is Priority#1.
Old Mar 30, 2002 | 07:21 AM
Monty's Avatar
Monty
Default Re: all aluminum smallblock? (billreid1@***.net)
If you're really interested in an aluminum block, I know where I can get you a Dart aluminum Rocket block, brand new for $3500. That's about $1000-1500 discount.
Old Mar 30, 2002 | 12:01 PM
DON M's Avatar
DON M
Ligenfelter has a 427 all aluminum SBC complete for only $18,000. :crazy:
Old Apr 4, 2002 | 03:48 PM
Greenbeast's Avatar
Greenbeast
Default Re: all aluminum smallblock? (DON M)
That conversion of for C5 LS1 engine!!
Old Apr 4, 2002 | 05:35 PM
vader86's Avatar
vader86
Default Re: all aluminum smallblock? (Greenbeast)
how much weight would a AL sb save over a iron one?
Old Apr 4, 2002 | 05:55 PM
Monty's Avatar
Monty
Default Re: all aluminum smallblock? (vader86)
A bare aluminum SBC block is aorund 90 lbs, a bare SBC block weighs 175 to around 200 lbs, depending on what casting, and what year it is. The iron SBC blocks made in the 80's are lighter than the one's made in the 60's and early 70's. An iron aftermarket block like a Dart, Motown, or Rocket block are right at 200 lbs due to the thicker cylinder walls, webs, and decks.
Old Apr 4, 2002 | 11:42 PM
korvetkeith's Avatar
korvetkeith
Default Re: all aluminum smallblock? (Monty)
Hey Monty, how much are Iron Rocket blocks from this place?
Old Apr 4, 2002 | 11:48 PM
Monty's Avatar
Monty
Default Re: all aluminum smallblock? (korvetkeith)
As far as I know, the iron Rocket blocks are selling at the regular price, which is $1895.00. If you're interested I could ask to make sure.
Old Jul 31, 2004 | 04:21 PM
90NormZ51's Avatar
90NormZ51
Default Motown Lite Block
The June Hot Rod had an article on World Products Aluminum Small Block that is coming out with soon. Just over 100 lbs. with sleeves. the best deal is the package as an upgrade to the Motown crate engines where the AL block adds $2,000 to the base price od the engine. The block is priced at $3,295 with nodular iron main caps and $3,495 with spayed billet caps.
Old Jul 31, 2004 | 06:06 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
YOu could buy a lot of nice parts for the price of an alumimum block. Not really worth it even if it was for racing, you get about a tenth in the 1/4 mile for 100lbs probably get more by jetting properly.
Now if it's for bragging rights that's a different situation
Old Aug 1, 2004 | 10:49 AM
korvetkeith
The lighter your car, then the performance gain would be greater. So say I got my '84 down to 2900lbs another 100 pound drop would be very hard to find, so an aluminum block would be cool. It would also be good getting more rearward weight bias, which is optimal for road racing (it's the kind with turns).
Old Aug 9, 2004 | 11:14 AM
Brc's Avatar
Brc
Default Lighter...
I have C2 with -03 Z06 engine and now the car weight aprox 2680 lbs and it felt wery light...Before the mods it weight 2910 lbs...First I plan to build "Big" smallblock but then one night I got the vision of that great new LS-6...and afterwards it was definitely right choice to my project. Nice engine in all level ...
Old Aug 9, 2004 | 09:51 PM
ZD75blue's Avatar
ZD75blue
That is a very light C2!
I havent done much thinking about the subject...
But an aluminum intake, heads, and thin wall headers with a titanium exhaust system... and of course the aluminum block would definetly shave some weight!
I wonder how much weight you could save just by cutting out the inner fenderwells and putting in some supports (ala thin race glass front clip...)
Hmmm!
Tube frame chassis
Light weight fiberglass
Aluminum motor
Light weight alternator
AL drive shaft
Carbon fiber half shafts
C4 style alum differential
Light weight track transmission
Alum/mag wheels
Gutted interiour
No power anything!
That! would be a FAST car.
Old Aug 10, 2004 | 01:29 AM
Brc's Avatar
Brc
Default C4 axle
The -96 Grand Sport rear axle save weight very much compare to that old "Hevy Weight metall" one ...
Only the trany T-56 weight more than Munchie...
Car axles balance is folloing
Front 1395 lbs
Rear 1290 lbs
Old Aug 10, 2004 | 04:52 PM
comp's Avatar
comp
ya' all alum. 427 sbc and a inch or two of engine set-back
Old Aug 11, 2004 | 10:09 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Front 1395 lbs
Rear 1290 lbs
Who did the C4 conversion? Are you running the 17x8.5 or 17x9.5 on the back? Very car.
Old Aug 11, 2004 | 10:29 AM
Brc's Avatar
Brc
I made hole car by myself and one of my friend helps me lot who have -63 convertible too...The project took abrox 3-years.
The rims are 8.5" front and rear
Tyres 235/50 front and 255/45 rear
To all aluminum smallblock?
