Building an LSX... Need help
Old Sep 29, 2010 | 03:57 PM
clif's Avatar
clif
St. Jude Donor '09-'10
Default Building an LSX... Need help
I am building a new LSX engine, piece by piece. I currently have a new LSX block from GM. I've ordered a Callies DragonSlayer, forged steel, crank, with Callies I-Beam Pr rods, Diamond Forged pistons with coated tops and skirts, AP rings, coated Main and Rod bearings, Cloyes Timing set upgraded to double helix, ARP Custom Head Studs, and Main Studs. Melling HP HV Oil Pump, and a few other parts. The bore will be 4.185. The stroke will be 4.125; for a 454 cubic inch beast.
I have a friend that owns a high-end machine shop, with 7-axis automated lathes, down to the manual lathe. They have many machines.
My question is, do you think a shop like this can machine my block successfully? They have asked for clearances and tolerances. Is this information available?
Old Oct 1, 2010 | 04:59 PM
chevy406's Avatar
chevy406
I would contact Diamond and ask them about the cylinder-to-piston clearance and cylinder hone finish. Deck height depends on your piston-to-valve clearance (if running a lot of duration) and what compression you are shooting for. They should probably just hit the deck enough to true it. Have then install the main studs and then align hone the crank bore. I also like to open up the oil drain back holes and smooth out any casting flash inside the block. You didn't mention if this will be boosted. If it is getting a lot of boost you should o-ring it too.
Old Oct 1, 2010 | 08:05 PM
clif's Avatar
clif
Yes, for now, I will use my ProCharger P1SC1-2. I may only make 7 PSI of boost. Next year, I will upgrade to a huge blower, to get around 20 PSI.
Thanks for the info so far. Eveyone, please send all you can for me!
To Building an LSX... Need help
