different heads on my L-48
Old Nov 29, 2010 | 11:47 PM
bucky-katt's Avatar
bucky-katt
Default different heads on my L-48
i have a stock L-48 in my 1978 corvette and i'm looking at maybe putting some heads with smaller chambers and maybe a little port work. i have no need for huge valves or really hogged out ports since this is strictly a daily driver. i just want a little more power than stock so i was thinking a mild cam and some heads with smaller chambers to give me a little more compression. this is a pretty low mileage motor and there was still some crosshatch visible on cylinder walls when i replaced head gaskets, so it's still a really solid bottom end. i'll either run the stock intake or a low rise aluminum with the freshly built q-jet. any suggestions head-wise? i have nothing at all against iron heads, in fact i prefer them as you can run less timing on them and still make the power an aluminum head does (since the iron holds in heat better)
