tranny?
Old Apr 9, 2002 | 05:51 PM
1996man's Avatar
1996man
Default tranny?
just as a ballpark, how much do you think it would cost to have someone take the 4 speed automatic out of a late model c4 (a4?)(3+4?) and put in a zf 6 speed? if i do the work myself? if i have someone else do it?
Old Apr 12, 2002 | 01:25 AM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: tranny? (1996man)
you can get a used 6 speed in carslile for $1500ish. i think you have to change the drive shafts,add clutch pedal & new bell housing w misc parts...clutch,new console, ect...$2000ish if you do it your self (btw cross your fingers the used tranny is good).if you send it out it could run from $500- $ 1000 for labor!by the way i think a new tranny will be in the 3g's area! :eek: good luck. :cheers:
