Programming question
Old Feb 17, 2011 | 10:47 PM
Filthy McNasty's Avatar
Filthy McNasty
7th Gear
Default Programming question
Hey have any of you guys running a 406 had to get the ecu reprogrammed.If so, does anybody know of a good programmer.Thanx
Old Feb 18, 2011 | 07:14 PM
jeff keyuk's Avatar
jeff keyuk
Filthy! Where are you located????
Old Feb 18, 2011 | 10:59 PM
Filthy McNasty
7th Gear
I live in north New Jersey.
Old Feb 19, 2011 | 08:19 AM
jeff keyuk's Avatar
jeff keyuk
Do you know "vette Doctors Inc" 52 Elm Place , Amityville .NY 631-841-0779 These guys are well know in NY!
Old Feb 19, 2011 | 10:39 PM
Filthy McNasty
7th Gear
Know I dont but Thanx I will contact them.
Old Feb 20, 2011 | 10:38 AM
jeff keyuk's Avatar
jeff keyuk
let me know how it go,s. Lets hear more about your car.
Old Feb 20, 2011 | 11:29 AM
Filthy McNasty
7th Gear
Well ,I recently bought a seasoned 400.Set it to Rogers speed shop to be set up as a 406.Brought myself a forged bottom end ,got the block machined and had them install a Howard's cam with these specs 234/242 @ .050 294/302 with .533"/548" lift and 112 Lsa.Brought some 210 cc aluminum heads with 2.02/1.60 valves(64 cc) which gives me a cr. of 10:8.1.Now I'm not an engine builder but I been reading about how to build a stout 406 for about two years.I tried to pattern mine block similar to something close to the Grumpy Jenkins build,on a budget(if you know what I mean)Ebay.I plan on using a Wieland stealth ram with 32lb injectors.I will bolt this up to a 700r4 tranny with a 2800 stall and a 390 diff gear.Would have liked to use my TPI intake but everyone keeps telling me its a restriction.Well anywho if I dont kill myself in the car. Ill keep you posted on how it works out.Thanx again Jeff
To Programming question
