Stripped a head bold, WTF now?
Old Apr 13, 2002 | 03:38 AM
Warlock's Avatar
Warlock
Default Stripped a head bold, WTF now?
Ok, so on my bro's 71 454 that we are building, one of the last bolts we were torquing gave way and stripped completely.
What's the best way to fix it? We are building a 550-ish hp engine. Nothing extreme. 10-1 comp...
drill it and use helicoils? Will those hold? It was one of the center ones toward the end of the head if it matters...
[Modified by Warlock, 11:40 PM 4/12/2002]
Old Apr 13, 2002 | 04:25 AM
Jvette73's Avatar
Jvette73
Default Re: Stripped a head bold, WTF now? (Warlock)
Pull the head and run a tap in all the threads. Check other headbolts for inperfections. If the bolt was the damaged item then you might get lucky and just need a new bolt. If all precautions were taken prior to assembly, its extreemly rare to have a head bolt strip off. It possibly may have bottomed out on gunk left in the hole before it was to its torqued spec. Excessive force placed on the bolt in this situation could cause stripping and or breakage of the bolt.
Old Apr 13, 2002 | 04:59 AM
Warlock's Avatar
Warlock
Default Re: Stripped a head bold, WTF now? (Jvette73)
The holes were chased, but the block side stripped, all the other ones troqued to spec. New ARP bolts. all the threads are trashed.
Old Apr 13, 2002 | 05:02 AM
Jvette73's Avatar
Jvette73
Sounds very strange. Wrong part # on the head bolts maybe. Its possible to put the wrong parts in the right box isnt it?
Old Apr 13, 2002 | 09:54 AM
TheOman's Avatar
TheOman
You bet it is possible. I had Pontiac rocker arms in Chevy P/N boxes direct from TRW. Dopes had the correct Chevy nuts and ***** in the box with Pontiac rocker arms. Check EVERYTHING trust NOTHING to be correct these days.
Sometimes you can just get a longer head bolt if the threads are OK down deep in the hole. Buddy did that with a 455 pontiaac engine. Not sure what you did to the 454 so you might be out of luck.
Old Apr 13, 2002 | 11:26 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
heli coil will work fine. cover and tape off the top of the engine with a piece of cardboard to keep out the chips and work away. i would use some type of fixture to make sure that you drill and tap the hole straight. use a drill bit with a negative angle on the tip to prevent the drill from grabing in the cast iron. :chevy
Old Apr 13, 2002 | 04:38 PM
MasterDave's Avatar
MasterDave
Moderator
I've done this before (helicoil that is) and my suggestion is to put a pencil magnet in one of the water jacket holes. Get it close to the hole you're working on on the bottom side. This will pick up most errant metal chips so they don't stay in your cooling system. Just pull it out a few times to clean off the chips. :cool:
Old Apr 14, 2002 | 10:09 AM
mountainmotor's Avatar
mountainmotor
The big Chevy uses two tad bit shorter bolts on the upper row at each end.When you remove the head,lay them all out and you will note the difference.Have though seen the ARP's all equal lenght before.These must have a thick washer put under them.Suggest a good threaded insert with a locking agent like the green locktite over a heli coil though and you might want to think about leaving the head on and using it as a drill guide,,,with grease smeared all around the hole to catch the shavings.
Old Apr 14, 2002 | 11:30 AM
clem zahrobsky
Cruise-In I Veteran
Default Re: Stripped a head bold, WTF now? (mountainmotor)
the only problem i have seen with BB chevy head bolts is that after market bolts are longer to allow for head bolt washers and they will bottom out in the bottom row on the passenger side,the front 2 holes. i am aware that SB have 3 different length head bolts but never saw it on BB. :chevy
Old Apr 14, 2002 | 01:33 PM
Warlock's Avatar
Warlock
Default Re: Stripped a head bold, WTF now? (clem zahrobsky)
With the Edelbrock RPM heads we used, the correct bolt kit has three different length bolts. Anyway, we used a small square to keep the drill at the right angle and repaired it with a helicoil. It torqued to spec, so it looks good. :cheers:
Old Apr 15, 2002 | 12:03 AM
snaketr's Avatar
snaketr
Something that I did not know until I actually read the ARP box. It says that you are not supposed to run tap through the head bolt holes. They have a special chaser for the head bolt holes. I have alway run a tap through them but I thought that was very interesting. I have had to use a heli-coil before on a 406 that I built. It has 11.1's and it has held up just fine.
To Stripped a head bold, WTF now?
