Best Automatic tranny for high hp?
Old Apr 18, 2002 | 01:37 PM
vader86's Avatar
vader86
Default Best Automatic tranny for high hp?
I was thinking that if i get over 400hp and more torque than i could handle with a 383 and a SR, that the 86's 700R4 would fail fairly quickly.
so what should i think about having done to it, beefed up with new TC and cooler (ill get those 2 either way) or a whole new transmission and if so what kind?
or should i think about swapping in a ZF6 or other 6spd? or is there a 5speed automatic that could handle it?
thanks
Old Apr 18, 2002 | 02:34 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Default Re: Best Automatic tranny for high hp? (vader86)
check out bowtieoverdrives.com, seems like a good deal to me on their level 2 trans.
Old Apr 18, 2002 | 05:35 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
One of the guys on the C-3 Forum put an 4L80E in his car, I had some links a couple of weeks ago to some other performance transmission places.
http://www.transmissioncenter.net/highperf700r4.htm
http://www.tpiperformance.com/index.html
Old Apr 19, 2002 | 12:45 AM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
thanks
ill let you know in a few weeks. i had my 700r-4 beefed up with shift kit about 500 miles ago with a 2800 stall converter....i just had a 383 stroker installed..im wondering if this things gonna hold up to the horse power? :confused: i have my fingers crossed but am already questioning if the tranny is gonna hold up? :confused:
[Modified by yoslambo1@cs.com, 11:48 PM 4/18/2002]
Old Apr 19, 2002 | 11:20 AM
ODennis's Avatar
ODennis
Hi vader86,
Don't be too hasty to discount your 700R4. I'm probably harder on my 700 than most are on theirs. Over the last 6 years I've averaged over 250 passes each year. Although I do freshen it up each year, it has withstood the rigors of 400+ HP. The 3-4 clutch pack is pretty much toast by 250 passes....keep tuned to what the tranny is doing when shifting 2-3 and 3-4 (you will have to lift to get it to shift into 4th). If you don't subject it to the kind of abuse that I do you should be OK for a long time. Good luck with your project!!! :)
Old Apr 19, 2002 | 12:49 PM
gkull's Avatar
gkull
Default Re: Best Automatic tranny for high hp? (ODennis)
ODennis - You said that you have to lift to shift 3-4. I was trying to think if I have to. :confused: With my 5000 rpm gov. I'm sure that it does.
700's can be built with a warranty for 850 hp. I put allot of bad miles on mine and I can tell that the 2-3 shift isn't as snappy as it used to be. At the drag races the 6800 rpm gov. was hitting the 7000 rev limiter sputter a few times. It's probably better for the rearend like that anyway. :seeya
Old Apr 19, 2002 | 07:59 PM
vstella's Avatar
vstella
You might want to check my thread in C5 Tech regarding my rebuilt "bulletproof " 4L60E rebuilt transmission.:yesnod: http://forums.corvetteforum.com/zerothread?id=282720 :eek:
To Best Automatic tranny for high hp?
