Performer RPM Air-Gap
Old May 1, 2002 | 10:32 PM
shotgun_000's Avatar
shotgun_000
Default Performer RPM Air-Gap
I want to use a Performer RPM Air-Gap on my 79 Corvette. The engine is an 87 model, w/aluminum heads. Will this intake, with a street avenger, fit under the stock hood. I have a low profile air cleaner, and looks like I have an inch or two clearance between it and the hood. Has anyone bolted a performer rpm-air gap on their 79 vette???
Thanks for any suggestions or comments!
Old May 1, 2002 | 11:03 PM
Ganey's Avatar
Ganey
Default Re: Performer RPM Air-Gap (shotgun_000)
Yes, it will fit nice & tight w/ a drop base air filter under the stock med rise hood..
:cool:
Old May 2, 2002 | 08:20 PM
Clink69's Avatar
Clink69
Yes, Mine did but thats a 69 SB, You probably have more room than I do...
check it out at
http://forums.corvetteforum.com/zerothread?id=219513
good luck
Chris
:flag
Old May 8, 2002 | 02:19 AM
rob75383's Avatar
rob75383
I suggest you paint the intake instead of getting a polished one...
You might have a lil' bit of trouble getting the vacuum port to fit under the secondary bowl of the carb. You could try to use a 3/4" spacer under, but I don't know how your hood clearance would be.
This is a very good dual-plane intake that made noticeably more power than the performer w/egr I had on earlier.
[Modified by '75 383 ElkGrove, 12:20 AM 5/8/2002]
Old May 8, 2002 | 03:55 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
i got an rpm performer airgap (polished) intake with a holly 750 on my vette (i know it isnt a c-3 but it is just as tight of a fit). we had to mill the airhorn so the combo would fit. it is tight but it fit. i suggest the polished.....it looks sooo good. good luck! :cool:
[Modified by yoslambo1@cs.com, 2:56 PM 5/8/2002]
Old May 8, 2002 | 04:06 PM
Mr. Sharky's Avatar
Mr. Sharky
I found that on an '80 L48 it would fit with a K&N drop base air filter.
To Performer RPM Air-Gap
