Question: 307 to 350??
Old May 3, 2002 | 09:25 AM
EZG63Conv's Avatar
EZG63Conv
Default Question: 307 to 350??
Hey folks,
Ordered a 350 custom engine that just came in. I checked the block number and it is T3970020 denoting a 307 block. Assuming it was bored out to 350 specs (Bore 3.875 to 4.00; stroke 3.25 to 3.48). Is this common place to convert a 307 block? Most ref materials I got only recommend up to .60 overbore on 327s & 307s. I'm concerned that the if I want to bore it out later to a 355 or 383 I won't have much to work with. Are they they basically the same core block (307 & 350)? Reply needed ASAP please!! EZ sends
Old May 3, 2002 | 11:13 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Question: 307 to 350?? (EZG63Conv)
the 307 block is a smaller bore then the 4.00 bore of the 350 also the 327 block is the same as the 350 with a bore of 4.00,but the 307 and the 327 crank is the same stroke.id stay away from the 307,even if you bore it .060 over your still not at a 4.00 bore yet.youre somewhere around a 339ci.
Old May 4, 2002 | 12:15 PM
Matt Gruber's Avatar
Matt Gruber
first thing i would do is to measure the bore and stroke.
To Question: 307 to 350??
