Vette Valve Covers
Old Dec 11, 2011 | 06:46 PM
TC233's Avatar
TC233
CF Senior Fox Bat
Default Vette Valve Covers
I am installing Comp roller rockers on my Camel hump heads. Is there any roller rocker from Comp that anyone is aware of that will not fit under the standard Corvette covers? I don't own a set of covers yet, and sure would hate to order them and find they do not fit over the rocker arms?
Old Dec 13, 2011 | 05:54 PM
impala66's Avatar
impala66
Default roller rockers
I'm running an older set (2001, they changed them a little and now added the word ultra) of pro magnum roller rockers 1.52 to 1 and use them with my stamped steel Chevrolet script valve covers. These rockers are steel and have smaller bodies then the aluminum. I also use the Fel pro gasket 1604 it's cork-steel-cork and gives you a bit more clearance. I'm not sure about the 1.6 to 1.
Keith
Old Dec 15, 2011 | 05:44 PM
TC233's Avatar
TC233
CF Senior Fox Bat
Keith
Thanks Keith, mine ate 1.5 to 1 and I found out from a friend they will fit. So now going to buy those chromed finned covers from Paragon, they are gorgeous.
Old Dec 16, 2011 | 11:04 PM
cv67's Avatar
cv67
St. Jude Donor '05
Paragon makes some neat stuff, Mr Gasket makes a very thick gasket for them also which works well fwiw.
To Vette Valve Covers
