'64 valve cover question
Old Feb 13, 2012 | 10:48 PM
jbutler's Avatar
jbutler
Default '64 valve cover question
my 64 did not have the original motor in it, it had a 350. In order to save some time and money I bought an engine from a local builder, another 350.
It came with an Edelbrock Preformer intake manifold that didn't have the oil fill tube.
To make a long story short, the valve covers I have are equipped with an oil fill / vent, and a PVC valve.
I would sure like to have aluminum Corvette covers, but I don't know if they would work or how to vent the engine .
Any suggestions would be greatly appreciated
Jim
Old Mar 22, 2012 | 11:48 PM
hotrod32's Avatar
hotrod32
http://www.yourcovers.com/valve_covers_11026.php
You will have to use a pcv valve cover, your 350 does not have the draft tube opening in the back by the distributor. THese cover are nice, and have a descrete opening for pcv function.
Old Mar 23, 2012 | 09:59 AM
jbutler's Avatar
jbutler
Thanks! Those do look nice.
Jim
Old May 25, 2012 | 12:17 AM
L84s R Us's Avatar
L84s R Us
I have a set of original Corvette valve covers that I used to run on a 350. They have a breather on each cover. The breather is about 3" long ang was placed right over the center of the word "Corvette"
They are perfect for your application and the closet thing to original out there. If you are interested,m I have to make sure they are in good shape, but I think $100 is pretty fair.
If you want to send me a regular e-mail address, I will send you some pictures.
M
Old May 26, 2012 | 11:23 AM
jbutler's Avatar
jbutler
Please send a couple photos to butler@nventure.com
Thanks!
Jim
Old May 26, 2012 | 03:20 PM
L84s R Us's Avatar
L84s R Us
Default Valve Covers
Jim,
I tried sending the pictures over to the address twice. for some reason it comes back to me as non deliverable.
Any other address we can try, or is there a reason they might not be going through. I have never had this kind of trouble before, so it moght be on your end.
Thanks,
monte
Old May 27, 2012 | 03:23 PM
jbutler's Avatar
jbutler
I'm not sure why jbutler@nventure.com wouldn't work, but you can try jbutler@pierce.ctc.edu
Old Jun 1, 2012 | 11:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
Couldnt he use an early style intake with the fill tube? Suppose blowby enters the lifter valley before it enters the heads so??
Some intakes come with a provision for this where a machinist could punch the hole for you. Then use the covers.
Someone correct me if Im wrong.
To '64 valve cover question
