Crowler, Hank the Crank, ck the guys at Competition Products, http://www.competitionproducts.com
They carry all of them I think, also have some Trick Flow Forged Cranks left.
crower makes one of the best but unless your making 2000hp it's not needed. scat makes a cast steel 9000 crank that could take 500hp all day long for a few hundred dollars. they have 4130 forged cranks for around 5-600 that could stand over 1000hp and for a little more you could have it nitrated. no one really beats scat for the bang per dollar in cranks. they also make GREAT rods.
I'm using the Scat 9000 series steel crank in my supercharged 383. Very nice piece, internal balanced easily. You can't beat them for price/performace. My shop didn't think a forged crank was warranted unless I was turning 6000+ rpm all day long.
An interesting note on the Scat 9000 cast steel cranks; they have a tensile strength of 105,000 lbs/in^2, which is the same as the old GM forged 1053 steel cranks; in comparison, cast GM cranks have a tensile strength of about 95,000 lbs/in^2. Vizard is a big believer in the 9000 series cranks for above and beyond 500 hp.
Just look on the web for stroker crank kits. For @ $1500 you can get a 4340 383 - 396 cubic inch master racing kits.
If you have a 350 4 bolt block. I would use a fully studded bottom end with better main caps. Or better yet have the block machined for splayed bolt main caps. Then buy a 3.875 forged stroker crank in your budget to build a 396 ci. Buy some $500 - $600 600 plus gram H beam rods. figure out what size dished blower pistons you need to get @ 8 to 1 compression. Blower pistons are different because the top ring is farther away from the piston top.
Then spend the extra @ $225 dollars and have your pistons thermal barrier coated
Matt - for blower motors you need to really look at the graph to figure out dynamic compression ratio as boost pounds change. it's very easy to cross the line and start requiring something higher than pump gas octane even with det controls and timing retards.
GRX - I don't leave home without my thermal coatings! Monty's wild TT is also having it done. I did it to run high compression on the street and plans for a 250 shot of NO2. With thermal coatings you can run 1 point higher C/R. Your right a 9 or 10 C/R static motor can be built if your going to run 100+ octane race gas whenever the boost is on. I have the books on blower motors, but unless I look it up I couldn't for sure say that 8.00 is perfect.
On this forum a guy from Texas has 600 some rear wheel HP out of a 408 ci small block. He stuffed in a 4 inch strocker crank in a 350 ci block. I have just seen to many broken pieces when you go too that extreme stroke length and high power. 3.875 strokers for 350 blocks make a wonderful 396 ci.
