Are all valve springs created equal ?
Jun 11, 2002 | 09:22 PM
Just curious, I'll be replacing mine shortly and dont want to skimp and have trouble.
Tripp
Jun 11, 2002 | 11:53 PM
Re: Are all valve springs created equal ? (evil-1)
Any name brand valve spring should be fine, the important thing is to match the valve spring to your cam.
Jun 12, 2002 | 02:42 AM
Re: Are all valve springs created equal ? (bence13_33)
Yep!
Jun 12, 2002 | 10:48 AM
Re: Are all valve springs created equal ? (NewVetteLover)
I think I'll be going with Manley...... Thanks
Tripp
Jun 12, 2002 | 11:25 AM
And also important is you install them at the proper installed height. Matched springs installed w/ different heights are effectivly NOT the same pressure.
[Modified by Twinnie, 12:18 PM 6/12/2002]
Jun 12, 2002 | 12:01 PM
With all the things that you have done. Have you considered the real next step? Solid Roller and or stroker crank!
Jun 13, 2002 | 01:22 AM
Re: Are all valve springs created equal ? (gkull)
gkull, thought about it but not ready to pull the trigger as of yet. Some tell me a properly setup LS1 350 will pull better then a stroker.
First I have to finish the tuning, I'm still lacking about 30rwhp and some 15ft lbs tq, then 373 gears (Getrag)
Jun 13, 2002 | 01:41 PM
Who ever told you that less cubic inches pulls better must not have a big enough CFM intake and too small injectors
Jun 13, 2002 | 09:30 PM
I agree with gkull. I'm still kicking myself in the **** for not stroking my motor out to a 496 :sad:. Cubic inches are easy horspower and torque adders.
Jun 14, 2002 | 02:00 AM
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
I third what Gkull and Bence said, no substitute for cubic inches
Jun 14, 2002 | 09:33 AM
Re: Are all valve springs created equal ? (69 N.O.X. RATT)
My 8-71 and I disagree with the 3 of you.
