I know its pretty mild but considering the stock 90 L-98 specs it should be a mild improvement shouldnt it? Those specs are with 1.5
I might be able to pick up a cam like this for little or nothing from a local engine builder. I'd plan on using it with stock heads, stock runners, ported plenum and ported accell base. (possibly a superam later on)
I forgot to include mods.
AFPR
True dual 2.5" exhaust with no cat, H-pipe and muffler elims
All the free mods
Ported Accell base
LT1 SLP shorty headers (modified to fit )
BPP air pump eliminator
Re: What about these cam specs.... (red90sixspeed)
Since your not bound by emmissions it would be feasable. Most smog legal cars top out with 219 dur. cams. The whole problem with a hot cam is it's peak power might be produced at a higher rpm point than the intake air flow will allow.
Also big duration H-Roller cams are an Oxy-Moron. Your limited to @6500 rpm because of the valve train weight.
Thanks for the info. I was a bit worried about the duration being so big and with any tpi system valve timing is allways a huge player. I may go with a zz4 cam since I can get one locally for $100.
if your local zz4 source falls i also have a new one, did a last minute chage to comp cams & now i have a new zz4 cam i never used. first $100 takes it
