Question about solid rollers
Old Jun 30, 2002 | 11:33 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Question about solid rollers
Are there any block mods required for 1987+ blocks to use solid roller lifters? I'm thinking about switching to a solid for higher RPM capability.
Just looking for info!
KM
Old Jun 30, 2002 | 02:45 PM
The Green Rocket's Avatar
The Green Rocket
Default Re: Question about solid rollers (88-406)
No mods needed.
Thomas
Old Jun 30, 2002 | 03:23 PM
95vettski's Avatar
95vettski
Late model blocks require a taller (.300) lifter to clear. Comp cams, Crane, Crower etc. all carry them. Or you can machine down the lifter bore and use a standard sbc lifter, but I wouldn't bother.
:cheers:
Old Jul 1, 2002 | 07:55 AM
Rkreigh's Avatar
Rkreigh
Default Re: Question about solid rollers (95vettski)
you might look at the comp cams extreme solids, they have an oiling channel and seem to hold up better on the street. some of the rollers have failed when idling for extended periods as the rollers starve for oil.
these oil channels fix that issue. good luck!!11
To Question about solid rollers
