Building a 427 stroker small block
Old Sep 10, 2013 | 08:46 PM
Huneycutt's Avatar
Huneycutt
Cruising
Default Building a 427 stroker small block
I'm working on a new stroker build and thought I'd share the progress. The crank is a K1 unit with a 4 inch stroke, and the pistons are 4.125 Bullets. The block is a Dart SHP with a standard height deck, so the longest rod I could use is 5.850 inches which made getting the pistons to clear the counterweights a bit interesting. Right now I've got the short block done. Here's a few pics:
[IMG][/IMG]
I'm also documenting the build on video and when it's all done will put it on the dyno. If you are interested in seeing it, here's the link:
http://www.horsepowermonster.com/2013/ultimate-stroker/
Thanks!
Old Sep 16, 2013 | 05:00 PM
xLxLxOxRxTx's Avatar
xLxLxOxRxTx
1st Gear
I would recommended putting a slant .45 on that angle on that blade 4548.
