installing new cam in old engine
Old Jul 12, 2002 | 11:26 PM
14-Paul's Avatar
14-Paul
Default installing new cam in old engine
a thought just occured to me::crazy:
if I'm gonna put a new cam in my old mid 80s 350, what about the cam bearings? would putting a new cam over old bearings work well? wouldnt there be conflicts with the surfaces or oil pressure loss? they say you gotta put in new lifters with the new cam, what about bearings? :chevy
Old Jul 13, 2002 | 02:14 AM
kenincanada's Avatar
kenincanada
Default Re: installing new cam in old engine (14-Paul)
Cam bearings rarely wear and would be very difficult to change without pulling the engine
Old Jul 13, 2002 | 02:30 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
the big problem will be getting the old lifters out because of the varnish on the lower part of the lifter. i have had to pull the lifters up as far as possible,remove the old cam and then push the lifters out the bottom. :chevy
Old Jul 14, 2002 | 11:41 AM
63FI's Avatar
63FI
14-Paul, you will be fine with the original cam bearings. I have never seen a set wear out. I have done many times what you want to do without a problem. If you come up with a lifter that does not want to come out, use something like a dental pick on the top of the lifter, like on the retaining clip
to pull it up, and then twist it out. Then again, unless your motor has a million miles on it, you won't have a proplem. You will see a big improvement in performance with a new cam grind.
Lou
Old Jul 16, 2002 | 01:00 AM
bigvette1's Avatar
bigvette1
Default Re: installing new cam in old engine (63FI)
Yep the old lifters could be stuck. But, squirt some carb cleaner on them and use a lifter removeal tool and they will come out without too much grief. As the others said, don't worry about the cam bearings they will be fine. Suggest you pull the posts in the C3 section about changing a cam on the SBC's for some sound advice.
To installing new cam in old engine
