Need some help MASFLOEFI
You're best bet is to work with Mass-Flo EFI (although you said they weren't much help). You really need to start out with a stock, factory tune in one of your computers so MassFlo has some idea of what parameters you're using and can work with you from there. (They don't do tunes. That's not their business expertise.)
They should be willing to work with you to see if any of their products are at fault, but that's about it. They may be able to recommend a tuner in your area that can get the EFI engine running correctly using their tuning software.
If you're not familiar with their software and/or the parameters that can be modified, definitely seek the help for a knowledgeable tuner as there are many ways to screw up an EFI tune without realizing it until you try to start the engine.
I know this isn't much help for the immediate problem, but I would definitely get some professional help with the tune. Good luck!
1) Was the engine purchased with the Mass-Flow EFI installed, or did you purchase the EFI system separately? Is this the Mass-Flow EFI system you have installed?
2) Who did the initial tune that included the Moates chip? (Is the Moates chip part of the Mass-Flow EFI system purchased, or an after market item?)
3) What was the targeted HP of the 383? (The HP target determines the flow rate of the injector to be used.) Do you know the flow rate of the injectors installed?
4) When you stated that the initial start-up run well before all the trouble started, did this happen before or after the tune?
5) I understand that the overly rich condition deceases in intensity when you turn down the fuel pressure regulator. What has me confused is "zero" pressure would mean no fuel flow within the rails. What is the fuel pressure supplied directly to the fuel rails from the fuel pump? (Fuel pressure greatly influences the amount of fuel an injector flows.)
It's not impossible that two computers could be bad; however, if the Moates chip is not part of the factory Mass-Flow EFI system, I would use the Mass-Flow chip first. (The chip contains the fuel map which in turn used to select the correct pulse width for the injectors. Getting the fuel map wrong causes all sorts of problems.)
If you can find out the answers to the questions above, it would be easier to help you troubleshoot the EFI system.
[I]Yes , engine was purchased w/efi installed. The link shows the current generation , I have the previous. Long build has taken over 5 years illness, funds, etc[/I]
The builder provided the engine specs to massflo who I assume did the initial set up. It was explained to me that the moates chip was a base tune and that the system would learn.
The engine dyno'ed at 446 HP, + 6hp from advertised. The build sheet is hard to read. Can I tell by looking at the injector?
Would have been after, i guess since there was no tune other than the initial set up
I just meant zero at the regulator, the fuel pump was free flowing. Wahlbro pump in a Rick's tank
As I mentioned I purchased a used A9L as recomended by massflo, I had the computer from massflo checked out and other than replacing the power supply was told it was fine. I get no error codes. Nothing has been changed or modified from the as purchased system.
The builder provided the engine specs to massflo who I assume did the initial set up. It was explained to me that the moates chip was a base tune and that the system would learn."
Since the Moates chip was part of the original configuration, I'd go ahead and use it. (I've personally had nothing but good experiences with Moates chips.) I'm assuming that the Moates F3 chip was installed when Mass-Flow checked out your system's computer and replaced the power supply. If not, please let me know because the fuel map is located on the chip, and that needs to be verified. (Most of the times, chips simply burn out due to a short circuit, but it's possible that a discharge of static electricity could have altered the chip's tune.)
Last edited by mr.beachcomber; Mar 10, 2015 at 11:51 AM. Reason: Edited response to question for easier identification
The engine dyno'ed at 446 HP, + 6hp from advertised. The build sheet is hard to read. Can I tell by looking at the injector?"
If the engine was targeted for roughly 440 HP, I'm guessing that the installed injectors are 36 LB/HR units based upon the RC engineering Fuel Injector worksheet.
I used 0.50 for the BSFC, 0.80% duty cycle, and 43.5 PSI (3 BAR) for the fuel pressure to calculate a 34.57 LB/HR (363 CC/MIN) injector. I rounded up to 36 LB/HR since that is a common injector.
If you can read the part # on the side of the injector and give me the color of the injector top, we should be able to determine what size injector is installed.
For example, my '89 Vette uses a Ford Blue Top F55E-A2E rated 262 cc/min (25 lb/hr) @ 43.5 psi (3 bar), resistance 14.4.ohms:
Here's and example.
I just meant zero at the regulator, the fuel pump was free flowing. Wahlbro pump in a Rick's tank"
This part still has me confused. The Wahlbro pump is probably this one rated at 255 liters per hour at 43.5 PSI. Knowing what fuel system pressure the injectors are seeing is important because although the injector's flow may be rated at 43.5 PSI, it will flow way more at 50 PSI. What does zero on your regulator mean in terms of actual fuel pressure?
For example: My '89's Vette's fuel rail pressure after the regulator at WOT is 35.5 PSI because I have a larger than stock injector installed. The stock injectors used a post-regulator fuel pressure of 43.5 PSI at WOT. (BTW the idle fuel pressure is always less than WOT.)
Is there any way that you can measure your fuel pressure to the fuel rails? (This would be the #1 source of your overly rich condition in my experience.)
Here's and example.
I cannot thank you enough for this help
Just be sure to document what has and has not been checked out when you finally take the Vette to a tuner when we get it running.
Was there something in the engine's dyno sheet/documentation that indicated this was a 40 LB/HR injector? Just curious. Thanks!
The regulator should be set such that a WOT, the injectors are receiving fuel at their rated psi which in this case is 43.5 or 3 Bar(ometic pressures). The system will simply by-pass any fuel that cannot be used.
I think that the problem that you're experiencing is related to too high a fuel pressure at the injectors. Raising the fuel pressure above that at which the injector's rated pressure will make the injector flow more fuel than advertised. (Most of the adjustable fuel pressure regulators are designed to crank up the pressure to allow more flow.)
I don't know for sure what type of fuel pressure regulator is installed on your system, but given the fact that it's aftermarket and a bolt-on to large and regular displacement SBC's, I'm guessing that it's adjustable. Some use thumb screws to increase/decrease the pressure. Other use a fixed slot with three or four setting options for the same function. The original GM were preset and used engine vacuum (or it's absence) to increase the fuel pressure.
Taking a fuel rail pressure reading would at least be a start in the right direction. It could be that the regulator isn't functioning properly because as you said turning it down to zero improves, but doesn't resolve the situation. Given the high flow characteristics of the Wahlbro pump, the injector might be seeing 60 psi of unregulated flow rather than the 43.5 psi they were designed for.
If so, you can download the installation/adjustment instruction sheet here. This unit uses an engine vacuum port to decrease the fuel pressure for idle, cruise, and low rpm operations. It is important that the engine vacuum port be connected for street operation. The typical installation would take engine vacuum from the same location that supplied engine vacuum to the power brakes booster. It's important enough to check to ensure that this port is receiving engine vacuum while the engine is running. (Wouldn't be the first time that a one-way, anti-backfire check valve was installed backwards killing the vacuum to the port.)
If this isn't the unit that you have, if you could provide any info on the fuel pressure regulator that you do have, it would be helpful as well as a description of what steps you take to adjust the fuel pressure on the unit.
I really think that too high a fuel pressure is what's causing all the problems you're experiencing.
1) What is the current fuel rail/regulator pressure with the vacuum port disconnected? This should be 40 psi according to the info from MassFlow EFI. (BTW, since your injectors are rated at 37 LB/HR at 43.5 psi, they will flow roughly 35.45 LB/HR at 40 psi which is closer to the calculated 34.57 LB/HR needed for 440 HP.)
2) Does the vacuum port work by lowing the fuel rail/regulator pressure when the engine is running. Need to check two things - ensure the port receives an engine vacuum signal at idle and that the vacuum signal is strong enough to allow the regulator to reduce the fuel pressure below 40 psi.
I think that item #2 is the critical pass/fail item. You can always reset the fuel pressure to a lower than recommended 40 psi to get the engine at least running; however, to have a streetable ride, the vacuum compensator must be working properly. I would trace the source of the engine vacuum to make sure the vacuum reading that you see at the source is the same that you see at the regulator.
Again, over the years I've seen all sorts of problems come into the shop from split hoses to check-valves installed backwards. Perhaps the most common mistake I've seen on carburetored Vettes is using ported vacuum (above the throttle blades) used instead of engine vacuum (below the throttle blades). Good luck!
