I am having a small block 427 being built with brodix track 1 heads. I want a single turbo. which one would you guys recommend I look at. I am looking for something in the range of 700hp.
t-76 should cover your 700 hp wants but a 427 ci motor can take alot more turbo than that if built properly. I personally would look at a 88 mm setup. Yes overkill but when you start to really decide to push the motor the system is there.
I just figure if you build it, build it once to the way you want. (do as i say not as i do lol) I would give John Craig at Limit Engineering a call or Innovative turbo a call and talk over your wants and such and get there view of the setup. http://www.innovativeturbo.com ... 1(805)526-5400
John Craig... 1 (520)453-7321
