Your thoughts on a 383...
I have a couple of choices on how to get it though...
1) I could simply stroke the 350 block in the car now. Most of the stroker kits are around $1000 (correct?) plus machine work and anything else that pops up unexpectedly can put in down for close to $2k. What's the price range to stroke a 350?
2) Buy a 383 short block and build the top end from there. ~$2800
3) The GM 383 HP stroker is really appealing, although the $3200 short block price tag is steep. You can get the crate motor for $3900, but I'm not really interested in the Vortec heads.
I'm not looking for a high HP motor, just a lot torque for the street without sacraficing any driveability. I'll probably go with a set of AFR 195s and 750vac Speed Demon for intake.
Stroking my block just worries me, you never know when you're jumping into a rats nest. Thoughts?
I was thinking roller cam too. But there lies another problem, everybody is complaining about this roller lifter shortage and the cr*p quality they're getting.
What would total cost be to upgrade to 383, including machining costs? Any estimates?
The 74 is history, upgraded to a 71 roadster. I wanted three more years of problems to fix.
On the cam,I have a custom can "flat tappet hydraulic" that will outrun the GM Hot Roller cam if interested with crackin throttle response and slight lope to idle. Easy 450 HP out of that cam,Pros heads and a 383 and some compression
Here are the specs of the engine:
Block: 350 4-bolt block bored .030 over - fully CNC machined and zero decked
Crank: Steel stroker crank
Heads: Dart Iron Eagle 215cc w/ 64cc chambers
Cam: Custom Solid 238/248 degrees @.050, .525/.540 lift 106 LCA
Rocker Arms: Lunati 1.5 Roller Rockers
Pistons: H600P Speedpro Hyperutectic
Dynagear oil system.
If you are interested - I can provide you with their address and phone#...
BTW - They have great tech support too!!
:cheers:
Olivier
