A/F ratio readings
Old Aug 15, 2002 | 06:49 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default A/F ratio readings
Quick question. I had my car dynoed a few weeks back and the dyno operator told me I was running rich (approx 10.8 AF ratio).
Recently I saw a thread in another section where the poster said that AF ratio readings taken from the tailpipe were different from those at the O2 sensor because he had catalytic convertors on his car. Based on the thread the conclusion I drew was that tailpipes AF readings may not be too accurate if you are running catalytic converters.
What is right? Can I rely on accurate info from the tailpipe sniffer if I have a cat on my car or should I be going off the O2 sensor reading?
[Modified by Red 90 L98 Coupe, 8:58 PM 8/15/2002]
Old Aug 17, 2002 | 10:24 AM
89vette's Avatar
89vette
Default Re: A/F ratio readings (Red 90 L98 Coupe)
The dyno operator told me that if the car has cats then the sensor must be put in the O2 bung and not the tailpipe. It was me that wrote that post. I'd call dynojet and ask them since they make the equipment.
Old Aug 18, 2002 | 09:57 PM
Frank75's Avatar
Frank75
Default Re: A/F ratio readings (89vette)
Please post if you get any further advice on this - I've wondered about the difference myself.
Old Aug 21, 2002 | 07:01 AM
The Dingo's Avatar
The Dingo
Default Re: A/F ratio readings (Frank75)
89vette, yes, it was your post that got me thinking. :) I've gotten some good info here and on the threads in the other forums I posted but I might call Dyno Dynamics (thats the sort of dyno I ran on) and ask them for their official version...
Frank75, I posted the same question in a few other forums because the initial response here was slow, FWIW here are the links:
C4 Scan & Tune http://forums.corvetteforum.com/zerothread?id=365833
C4 Tech & Performance http://forums.corvetteforum.com/zerothread?id=365835
To A/F ratio readings
