400 block question
Old Aug 24, 2002 | 02:29 PM
Caboboy's Avatar
Caboboy
Default 400 block question
i've read a lot about the steam holes and drilling the new heads, but i also see guys talking about tapping and plugging them(the steam holes). what are the details/ advantages/ disadvantages to plugging them? is that just something you do to a track motor because it doesn't matter anyway? :confused:
my block is gonna be used in normal traffic conditions and i want to give myself the best chance i can at avoiding heating issues. tia
Old Aug 24, 2002 | 03:08 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: 400 block question (Caboboy)
The "poop" on steam holes, from my experience, and lore, is that they are not needed for sustained operation at speeds over 3500 rpms. I believe that the only reason to plug the holes in the block, is to stiffen the deck, for extreme usage applications. I have an old pick up with a factory installed 400. While doing a "quickie" rebuild years ago, I swapped on a pair of non-drilled, 350 heads. When I asked my machinist about the steam holes, he replied, "you don't need 'em". I think he might have been blowing my off, because he was too lazy to drill them. With my 4.11 gears, my engine spends a great share of its time in the 3-4000 rpm range, and even in around town driving, I've had no problems. I would, however, not chance this again. For everything but an all out racer, I would leave the steam holes in the block open, and in a street use application, I would make sure the heads and head gaskets had holes to match. I've had no problems, in my situation, but I wouldn't do it again. Good luck and RACE ON!!!
Old Aug 25, 2002 | 11:28 AM
Caboboy's Avatar
Caboboy
Default Re: 400 block question (CFI-EFI)
Thanks CFI-EFI, great info and exactly what I was lookin' for. There's so much goin' around about 400s and heating, it's tuff to separate fact from fiction. First hand experience is so important. Nice to hear you're a few years into your swap w/o problems. And, I agree, why take the chance if there's no tangible return? I'll just go w/ 400 gaskets and drill the heads. Thanks again!
Old Aug 25, 2002 | 06:58 PM
No Go's Avatar
No Go
Here is some more info from what I gathered when I built my street 406.
Street 400's need the holes in the heads (for the above stated reason-low rpm operation).
Many will plug the large deck holes (not steam holes) in the block with plugs,deck the block flat, and then drill smaller holes into those plugs-this increases block rigidity.
I haven't heard of plugging the block's steam holes...don't know why unless you want that little bit more rigidity...?
I left everything stock with drilled 350 300HP heads and Fel Pro gasket. Engine never ran hot with stock 69 Nova radiator.
Old Aug 25, 2002 | 10:17 PM
CFI-EFI's Avatar
CFI-EFI
Your comment caused me to think about, just how long it had been. It was either in '86 or '87. Not too long after I bought my present Corvette. The Vette engine is TOTALLY worn out. I hope the truck isn't close behind.
I have to agree with the above. I have never heard of anyone closing up the steam holes. Just the main holes like stated. RACE ON!!!
Old Aug 26, 2002 | 10:18 AM
Caboboy's Avatar
Caboboy
Default Re: 400 block question (No Go)
thanx no go. did you plug yours? any problems? since i'm not gonna pound on it (too much :reddevil ) i'm inclined to just leave it alone and move forward like any other motor. am i thinking right on this?
Old Aug 26, 2002 | 11:29 AM
MrJay's Avatar
MrJay
We have done a few 400+ engines and you plug the steam hole if you are going to O-Ring the block and run Copper head gasket, because the pleace where you have to cut for the o-ring is over the steam hole in the block.
Jay
Old Aug 27, 2002 | 01:27 AM
Caboboy's Avatar
Caboboy
Default Re: 400 block question (MrJay)
MrJay, would I want to o-ring the block? Is that something done short term on a track motor but not a street motor? Does the o-ring just support the copper gasket to keep it from blowing and thereby allow you to reduce the quench?
Would my needs be best served with a 400 block felpro of appropriate thickness? Geeze, all these options are a new game to me from my last motor circa 1965......... I am SUCH a dinosaur :lol:
Old Aug 27, 2002 | 10:12 AM
MrJay's Avatar
MrJay
No Caboboy you would not nead to do that, it is done on engines that are going to use blower or a lot of nitrous but since you are just going to use it on the street, you are ok just go with a good head gasket.
Jay
Old Aug 27, 2002 | 11:45 AM
Caboboy's Avatar
Caboboy
gotcha. thanks a lot for the info! i think i'm gonna put this together like any other motor and just make sure my cooling system is tight.
Old Aug 27, 2002 | 07:26 PM
No Go's Avatar
No Go
Only thing I did was drill the cylinder heads for the steam holes...since they were originally on my 300 HP 350 engine. Fel Pro gaskets and ran like a top.
Will be reinstalling it with new rings/bearings/new cylinder heads/EFI (all for more power) when my Nova is off jackstands.
To 400 block question
