went carb, now 14" or 16" air cleaner better?
Old 11-22-2015, 04:52 PM
pologreen1
pologreen1's Avatar
Default went carb, now 14" or 16" air cleaner better?
What are the benefits of either.
Motor is somewhere around 650-700hp 434. 4" Z28 cowl scoop. Going cowl induction.
Old 12-21-2015, 12:39 PM
mr.beachcomber
mr.beachcomber's Avatar
Back in the early 70's Holley engineers recommended that all Chevy owners with 750/780 carbs use the four inch tall 14" tall truck filter element as it was the least restrictive filter that would fit into the cold air boxes available for Corvettes and Camaros. Now you have better choices with K&N and AirHog elements available.
Go with the air cleaner that has the least restrictive element and fits inside your cowl induction cut out. If you're making that much horsepower, you don't want your filter element restricting the air flow to the carburetor.
techinspector1 (08-18-2017)
Old 03-14-2016, 04:57 PM
rdroket
rdroket's Avatar
A 16 inch air cleaner wont fit . It will hit the distributor.
Old 10-05-2016, 07:57 PM
jdcfrank
jdcfrank's Avatar
I'm using a 14" with a 4" filter on mine but I
have the hood modified.
To went carb, now 14" or 16" air cleaner better?
Quick Reply: went carb, now 14" or 16" air cleaner better?
