lean engine problem
Old Sep 3, 2002 | 10:47 PM
ICANTDR55's Avatar
ICANTDR55
Default lean engine problem
This is what I have guys; vortec engine 355cid cam specf, 242/252 @ .050 with 525/540 lift with 110/106 lsa. vict. jr. single plain , roller rockers, 830 holley carb. hooker headers, 3:73 gear 3000 stall. The problem is the engine is leaning out bad. made 2 passes and checked the plugs. The tips are as if we never had any runs at all on them; still white. compression is 9.6:1. Is a roller set up if it make any difference. what do you guys think might be the problem? have not gotten 1/4 time only 1/8. ran 7.45 and feel if I get this problem fix, I might see 7.20`s or better. :confused:
Old Sep 4, 2002 | 06:01 PM
45ACP's Avatar
45ACP
:confused: Why do you not think the answer is a richer a/f mixture via a well-tuned carb?
Are there any other problems that you have not mentioned?
