Should I o-ring????
Old Sep 9, 2002 | 02:49 AM
KLLRVET's Avatar
KLLRVET
Default Should I o-ring????
I have an 11.5:1 409 ci LT1 motor. I am planning on spraying up to a 200 hp shot of NOS. Do I need to o-ring?
Thanks in advance
Old Sep 10, 2002 | 02:32 PM
mountainmotor's Avatar
mountainmotor
Default Re: Should I o-ring???? (KLLRVET)
I think you do need some extra sealing but believe Felpro makes a gasket for your heads,a reciever groove must be machined into the head but then no messing with the piano wire and such,something to think about is you nominal compression a with NOS on top of it,could be 15.1 or more ?Who knows with out putting the pencil to it? Cam plays a role as well.
Old Sep 10, 2002 | 05:36 PM
KLLRVET's Avatar
KLLRVET
Default Re: Should I o-ring???? (mountainmotor)
Actually, thats exactly what I was thinking I wanted to do. I really did not want to take the bottom end apart to o-ring the block, I felt the heads should do the trick.
Thanks,
Tony
Old Sep 11, 2002 | 06:43 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
guys i would not mess with o ringing at that power level belive me i had a friend oring his 9 second mustang big super charger boost it was a nightmare geting it to seal for everyday use at 200 hp nos i dont think you would need it yet now if you were pushing 350-400hp ouy of a dual fogger or a big plate system i would consider it but believe me you might not be happy with the oring especially if you want to drive it everyday :D
Old Sep 12, 2002 | 03:34 AM
mountainmotor
Default Re: Should I o-ring???? (CORKVETTE1)
We are not talking about oringing,just a reciever groove in the head for a special gasket,doing this often does "more" than stopping a blown head gasket
[Modified by mountainmotor, 1:37 AM 9/12/2002]
Old Sep 14, 2002 | 11:47 AM
Bruce's Avatar
Bruce
You don't need to O ring it. When those whom O ring it, they are super/turbo charged with 25-35psi of boost. For 200 shot no need to. Agostino built a lot of high hp Nitrous stroker LT1 motors, they never O ring it. The nitous shot they use ranging from 200-400hp only use Fepro gaskets.
Bruce
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stage II heads
Old Sep 15, 2002 | 06:47 PM
kawboy5792's Avatar
kawboy5792
i dont think i would o ring it, but you may want to consider different gaskets, including the possibility of going to copper head gaskets.
To Should I o-ring????
