Carb Help - High Idle
Old Sep 14, 2002 | 09:36 PM
Jack71's Avatar
Jack71
Default Carb Help - High Idle
I have a Holley Street Avenger w/ Electric choke that is idling around 1500rpm. The weird thing is I just put on a new exhaust and this problem hits.
The choke doesn't appear to closed. So before I just adjust the idle screw, could these symptoms be caused by any other carb problems?
These carbs are a pain, because there is really no literature specifically for these models.
Thanks in advance...
Jack
Old Sep 16, 2002 | 02:26 AM
Lohkay's Avatar
Lohkay
Default Re: Carb Help - High Idle (74jack)
1500? I'd just go ahead and play with the idle screw. get it down to 700 if u have a manual tranny.
Old Sep 16, 2002 | 08:03 PM
sinistervette's Avatar
sinistervette
Check for a vacuum leak first. Also check to make sure that the secondaries are not "stuck" open just a little. Check the linkage for the choke's high idle, it might not be returning all the way. There might be a "idle screw" also on the choke linkage, if there is, back that one off first. If it slows the rpm down, you have linkage issues, if not double check vacuum leak. If nothing found, go ahead and just back off idle speed screw. Hope this helps. Good luck. :cheers:
Old Sep 21, 2002 | 11:59 AM
Jack71's Avatar
Jack71
Default Re: Carb Help - High Idle (sinistervette)
Its definitely the choke linkage or electric choke itself causing it. Its now releasing causing it to stay at fast idle. I tried adjusting the electric choke clockwise without success.
Damn these Avengers. Does anybody have a manual for a 670cfm vac secondary Holley Avenger they can copy & send me? That would be very helpful. Holley has nothing on their website and doesn't even list the carb# in any of their tech docs.
A service rep said they would send me something, but that may take months.
--Jack
To Carb Help - High Idle
