Butterfly Exhaust Valves
Old Jan 31, 2017 | 08:55 AM
jmoney127's Avatar
jmoney127
Default Butterfly Exhaust Valves
Has anyone installed the butterfly exhaust valves on their c6 or similar vette? Obviously they had the npp option from the factory but I have a borla system that I really like but wouldn't mind valves for when I'm idling or just cruising around. Did you guys install them yourself or take it to a shop? If you took it to a shop how much did they charge and where did you run your wiring on the undercarriage?
Old Feb 6, 2017 | 10:41 PM
Medicdiver's Avatar
Medicdiver
St. Jude Donor '13
They are vacumn actuated, not electric. Not an easy way to install on other pipes.
Old Feb 6, 2017 | 10:51 PM
jmoney127's Avatar
jmoney127
all of them are vacumm actuated? I swore they were electric powered and most people ran them off the cig lighter in the center console?
Old Feb 7, 2017 | 07:21 PM
Medicdiver's Avatar
Medicdiver
St. Jude Donor '13
All the factory ones are vacumn actuated. The mild to wild you hear about being wired into cigarette circuit on some cars is an electronic bypass so you can switch them on and off with a switch. The valves are still vacumn actuators just have a vacumn switching valve that turns on and off the vacumn supply.
To Butterfly Exhaust Valves
