Blow holes through this build...
Forged L92/L9H long block with VVT and whatever spec cam Comp Cam or someone else tells me with LS VVT experience
3.185" stroke crank
my own pneumatic valve spring system that's in development
12:1 compression ratio
Minimum 9000 rpm target
ProEFI 128
Going into a Factory Five GTM that will run time attack
Moving toward the higher end of static compression numbers because that is generally what NA high rpm motors do but I don't know what the science is behind picking it...
3.185" stroke crank
ProEFI 128
Received 3,043 Likes
St. Jude Donor '05
