External dimensions of big block engine?
Old Oct 22, 2002 | 04:46 PM
aww999's Avatar
aww999
Default External dimensions of big block engine?
Hi all,
I'm planning on building a rod/dragster with a blown big block chevy engine in it, I've made some posts on here before about engins etc but no I'm pretty much set on a big block. I haven't decided what the donor car is going to be yet, basically because I'm not sure how big the engine will be!
I've done a couple of drawings of the dimensions I think I need - apologies for my atrocious paint skills! I don't need exact numbers to 1/1000th of an inch, but if someone has a block on an engine stand in the garage and could attack it with a tape measure, it would be REALLY useful! I'd go and measure one myself if I could, but american V8's are a bit thin on the ground round my way! (UK - where two litres is a "big engine" - that's less than two cylinders of a big block!)
In case the drawing doesn't make any sense:
A: Centre of flywheel to top of valve cover
B: Centre of flywheel to bottom of sump
C: Cnetre of flywheel to side of engine
D: Centre of engine to side of valve cover
E: Rear face of flywheel to centre of engine mount (I drew the arrow in the wrong place in the drawing!)
F: Total length of engine from rear of flywheel to front of water pump (I guess that will stick out the furthest?)
I know different heads, sumps, accessories etc will all make a difference to the measurements, I just need to know some rough numbers to see which of my prospective donor cars are feasible propositions.
I really would be grateful if someone could help me out on this, or maybe point me in the direction of a webpage with this info on it? Thanks very much in advance guys :cheers:
Adam
Old Oct 23, 2002 | 08:51 AM
71coupe's Avatar
71coupe
Default Re: External dimensions of big block engine? (aww999)
I have the info you need in one of my engine swap books in the garage. I'll look for it. Drop me an email in case I forget. You may want to check out the plastic models they sell. They are molded off a real motor & used for displays. Look in the ad section in Hot Rod or Car Craft.
Old Oct 24, 2002 | 02:32 AM
Light84vette's Avatar
Light84vette
Default Re: External dimensions of big block engine? (71coupe)
I could use this info too. :yesnod:
Old Oct 24, 2002 | 01:26 PM
GregP's Avatar
GregP
If you still need them e-mail me at Juliet's address (juliet@annapolis.net) so I get it at home and I'll send them tonight. I have an old rod annual with basic envelope dimensions for a whole string of engines.
-Greg
Old Oct 24, 2002 | 02:37 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
i have a copy of GM prints,if you need it email and i will scan. :chevy
Old Oct 24, 2002 | 03:26 PM
aww999's Avatar
aww999
Default Re: External dimensions of big block engine? (clem zahrobsky)
Clem, Greg, I have emailed you both. Thanks for responding!
Old Oct 24, 2002 | 05:57 PM
GregP's Avatar
GregP
Ok, here they are:
Length: waterpump pulley to bellhousing SBC: 30.5 BBC 32.5
Length: water pump pulley to back of distributor SBC: 26.5 BBC 27.0
Height: bottom of stock pan to top of valve covers: SBC20.5 BBC 23.5
Height: bottom of stock pan to top of carb: SBC 25.0 BBC 29.0
Width: across valve covers: SBC 19.5 BBC 22.0
Width: across stock exhaust manifolds: SBC 26 BBC 27
These are from the 1975 Rod Action yearbook.
-Greg
Old Oct 24, 2002 | 10:01 PM
Light84vette
Default Re: External dimensions of big block engine? (GregP)
Which big block is this the 502 block or the 427/454 block? But hey its not so big that it cant be fitted into a C4 now is it?
Old Oct 25, 2002 | 08:58 AM
71coupe's Avatar
71coupe
I found the book! but GregP's reply has more info. :yesnod:
Old Oct 25, 2002 | 09:03 AM
aww999's Avatar
aww999
These dimensions are for the 454 block. I went out last night and measured up, and it appears a blown big block will fit - this is the kind of effect I'm hoping for:
And I bet you all thought I was going to put it in a corvette . . . ;)
Just gotta try and track down a 4-bolt 454 block in the UK now!
Thanks again for all your help guys :cheers:
Old Oct 25, 2002 | 09:09 AM
GregP's Avatar
GregP
Default Re: External dimensions of big block engine? (Light84vette)
Unless it's a tall-deck (truck or aftermarket) block the 396/427/454/502 dimensions are all the same.
Old Oct 25, 2002 | 08:35 PM
Light84vette
Thanks fo the specs on the Big Block. Also how much is the weight diff between the Big block vs. the small block.
To External dimensions of big block engine?
