Pistons are in...
Old Nov 8, 2002 | 09:45 AM
Ken73's Avatar
Ken73
Cruise-In III Veteran
Default Pistons are in...
And yes, that's Glyptal (electric armature enamel) in the valley..
I put all ARP hardware on the bottom (main studs, new rod bolts.)
Hopefully it'll be to this stage in the next month.. I just set everything on to see how it'd look...
:cheers:
Old Nov 8, 2002 | 08:05 PM
redwingvette's Avatar
redwingvette
Default Re: Pistons are in... (Ken73)
Looking good. What heads are you using?
Old Nov 8, 2002 | 11:17 PM
Ken73's Avatar
Ken73
Default Re: Pistons are in... (redwingvette)
L98 heads off of a '90 Vette that I bought from a forum member. The exhaust guides were a bit worn but I didn't expect them not to be, really. Exhaust guides tend to wear faster; I'm having bronze sleeves put in the exhaust, and I'm going to ceramic coat the heads just like I did with the pistons.
Old Nov 17, 2002 | 02:41 PM
69stingray's Avatar
69stingray
What manifold is that?
Old Nov 17, 2002 | 06:37 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Looks good! :yesnod: You have about as much garage room as me! :lol: :lol:
Old Nov 17, 2002 | 08:06 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Pistons are in... (69stingray)
That's a crossfire manifold with custom lid :)
Old Nov 18, 2002 | 05:41 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
What cam are you using? Looks great BTW! Congrats! :cheers:
Old Nov 18, 2002 | 07:12 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: :cool:
Old Nov 22, 2002 | 03:39 PM
Ken73's Avatar
Ken73
Default Re: Pistons are in... (binksZ06)
I'm using a Crane Fireball 290 cam - it doesn't make any sense to use this cam on most cars, but it will work VERY well on a CrossFire with the single pattern. Specs are 216/216 @.050", 290/290 (advertised) 110LCA, .454"/.454" lift. I've got 1.6:1 roller-tip (stamped steel) rockers to go with it.
And yes, that's a custom lid I made out of phenolic sheet to get rid of all the junk on the underside of the stock lid (so it's smooth) and reduce heat that gets transferred to the throttle bodies.
To Pistons are in...
