Small block Cam into Big Block
Old Nov 20, 2002 | 04:09 PM
GRX's Avatar
GRX
Default Small block Cam into Big Block
Is it possible to install a 350ci block cam into, say a big block? Some aftermarket block manufacturers design there small block to accomodate a big block cam. I'm wondering if it is possible to retrofit it with a small block cam? TIA
Old Nov 20, 2002 | 05:47 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Default Re: Small block Cam into Big Block (GRX)
No, I don't think so. If nothing else there is a big difference in length and spacing between cylinders as well as the order of valves in the heads.
What you are probably referring to is the use of big block size bearing journals in custom small blocks. This allows a larger lobe to physically pass through the hole as well as you can use a stronger cam core in a mega rpm high spring pressure deal.
JIM
Old Nov 20, 2002 | 08:04 PM
GRX's Avatar
GRX
Default Re: Small block Cam into Big Block (427Hotrod)
Ah yes...that must be what it is. So the cam HAS to be a CUSTOM cam...not only the lobes but the bearing surface as well????
To Small block Cam into Big Block
