Scorpion Roller Rockers 7/16" studs
Anyway these are brand new with the exception of being installed adjusted, then removed after we couldn't find centerbolt valvecovers to fit both them and a Superram.
These are killer RR's. Many of the hot rod engine builders around here are using them. The trunion bearings are large as are the roller tip bearings. They are blue anodized aluminum bodies. They are a split set of 1.5 and 1.6's. They are in the original box. $225.
